Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - AAT vs AEL ploki erinevus
Pealkiri: AAT vs AEL ploki erinevus (Vastuseid: 3 | Vaatamisi: 2118)
JanP
Registreerunud 04.12.09
Auto: 240, 300
postitati 24.03.15 12:41 Tsiteeri
Mille poolest AAT ja AEL plokid erinevad? Kas AEL-le AAT plokk istub alla? Ja vastuseks küsimusele, miks, siis enda AEL plokki tuli auk sisse.
postitati 25.03.15 15:56 Tsiteeri
http://www.audifans.net/ftopict-36846.html
yrks
Registreerunud 08.12.06
Auto: Audi C4 A6 2,5TDi Quattro, MB E280 CDI
postitati 27.03.15 19:58 Tsiteeri
kui audi 100 AAT võtta, siis vända signaal saadakse hooratta pealt, teistel tuleb see plokist, hammasrihm on ka pikem ning 1 rullik oli ka rohkem. Kui 1m hooratta paned siis ei ole 100 mootoril ka suurt vahet, A6 hammasrihma komplekti sai ka panna kui selle õlipumba otsakaane ära vahetad....
A6 AAT sobib 1:1 le. pihustid tiba väiksemad, juhtmestik sama.
JanP
Auto: 240, 300
postitati 28.03.15 17:13 Tsiteeri
Või oskab ehk keegi midagi ploki ja kaante sarnasuse kohta öelda Volvo D5252T vs AEL?
[PHP: 15.0% - SQL: 85.0%]
