Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890 Eesti Audi Klubi foorum - Audi 100 c4 2.3 98kw Mootor jõuetu.
Registreerunud 11.12.13
Auto: 1.Audi 80 B3 2.0 83 KW (1991) 2. Ford Scorpio 2.5D 3. Audi 100 2.3 98 KW 1992
postitati 21.03.15 19:02
Tere foorumlased!
Mure selline, et paned auto käima läheb kenasti pöördesse aga siis, kui hakkad sõitma siis umbes peale 5 kilomeetrit ühtlase kiirusega sõites hakkab
vaikselt jõud kaduma, läheb järjest uimasemaks ja kiirus kaob.
Ise kahtlustasime, et äkki bensufilter umbes ja, et äkki lambda ?
Kes oskab aidata, oleks väga tänulik.
MaarjoM
Registreerunud 26.12.14
Auto: audi 100 2.3 E C3
postitati 22.03.15 09:04
Tere,
Selle probleemi põhjuseks võib tõesti olla umbes filtrid. Et selleks kinnitust saada, järgmine kord kui mootor hingest kinni tõmbab, jäta hetkeks
seisma ja käivita uuesti, ummistuse korral peaks mootori jõud vähemalt hetkeks taastuma. Kui see nii on siis viska pilk kütusepaaki, mul oma audil oli
paaki 25 aasta jooksul "jama" korralikult kogunenud. Kontrolli kindlasti ka pumba otsas olevat peenfiltrit. Vaheta kapoti alt bensufilter ja looda
et probleem on kadunud. Kui miskit ei muutu on asi juba keerulisem.
olavi.peramets
postitati 22.03.15 16:04
Selge!
Proovin ära kõik variandid, tänan sellegipoolest!
J.Aru
Registreerunud 28.07.12
postitati 25.03.15 05:31
Võib proovida ka seda, et jätta kütusepaagi kork lahti või siis kui jõud kadunud on lahti keerata. Kui vaakum sees on siis on arvatavasti viga leitud.
prual84
Registreerunud 20.11.07
Auto: audi s4(ajalugu) a3 hetkel
postitati 25.03.15 06:57
Sama seis oli mul 2.6 mootoriga ja viga oli ummistund katis,sai eemaldatud ja sõit jätkus.
[PHP: 24.4% - SQL: 75.6%]
