Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi
Pealkiri: Audi (Vastuseid: 2 | Vaatamisi: 1502)
MarkoRohtla
Registreerunud 20.03.15
postitati 20.03.15 17:14 Tsiteeri
Audi
audimees001
Registreerunud 10.03.11
postitati 20.03.15 18:52 Tsiteeri
Turbo rõhuklapp on korras? Võta õhulugejal juhe tagant ära ja vaata kas minek tuleb tagasi!? See 110kw oma seal tõenäoliselt küll toimima ei hakka. Pumba enda kood peaks olema pumba küljepeal siledal pinnal sisse nö söövitatud. Nii 110/114/120/132kw on mitut erinevat koodi pumpasi. Näiteks kui 114 juba on mitu erinevat koodi, siis pead ka arvestama, et see teine vb ei sobigi kui kood erinev kuigi on ka näiteks 114kw. Kuid mõnele sobib ka teise koodiga. Kõige parem revalist järgi küsida kas sobib või mitte. Seal jagatakse meelsasti telefoni teel seda infot. Edu vea leidmisel igatahes!
MarkoRohtla
postitati 20.03.15 19:17 Tsiteeri
Õhulugeja sai proovitud, selles probleem pole!
[PHP: 9.6% - SQL: 90.4%]
