Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Sillastend Tallinnas
Pealkiri: Sillastend Tallinnas (Vastuseid: 6 | Vaatamisi: 1694)
wautzer
Registreerunud 09.10.09
Auto: Audi a8 (d3) 4.2TDI V8
postitati 17.03.15 17:27 Tsiteeri
Tere.
Soovitage Tallinnas mõnda head silastendi kohta kus asi ka korralikult õigeks saab. Flamekost juba võtsin pakkumise + seal pakuti veel õhkvedrustuse reguleerimist ??? Mida nad huvitav seal veel reguleerivad.. Auto peaks sellega ju ise tegelema, või kuidas ? Ühesõnaga , kellel on häid kohti soovitada .. siis ootan pakkumisi.
Autoks a8 (d3) 2006.a
mtaudi
Registreerunud 26.02.07
postitati 17.03.15 18:52 Tsiteeri
Aga küsi järgi siis, mis see õhkvedrustuse reguleerimine on - ju nivooandurite kalibreerimine vms. Ise tegin alles reedel Flamekos sillaregulli ja olen tulemusega väga rahul.
Ja ma ei saa üldse aru, miks peab foorumis seda küsima ja miks ei ole suud peas, et otse pakkumise teinud ettevõttele sellised küsimused esitada. A8 jõuad osta, aga 18€ ei jaksa maksta, et kõik tipp topp korras oleks.
seitsmene
Registreerunud 10.05.06
Auto: A8 4,2
postitati 17.03.15 18:53 Tsiteeri
Algselt postitas: wautzer
Tere.
Õhkvedrustus tahab ka aegajalt kalibreerimist. Seda küll sageli ei tehta. Kui Flameko ei meeldi, siis võib silda reguleerida ka näiteks Tõsturis - http://www.tostur.ee/Kontaktandmed_709
wautzer
postitati 17.03.15 20:17 Tsiteeri
Algselt postitas: mtaudi
Momendil polnud küsimus ju rahas!!! ??? Kuna audi on mul esimene ja ka ühtlasi õhkvedrustusega! Küsisin sellepärast , et miskit ülemäärast pähe ei määrita.
wautzer
postitati 17.03.15 20:20 Tsiteeri
Algselt postitas: seitsmene
Tere.
Tere. Tänan vastamast.. pole Flameko vastu midagi :) lihtsalt uurin maid, kuna pole varem kokkupuudet olnud.
seitsmene
Auto: A8 4,2
postitati 17.03.15 20:40 Tsiteeri
Õhkvedrustuse kalibreerimine pole iseenesest tingimusteta vajalik. Aga soovitatakse korra aastas. Kui näiteks tahtmine autot madalamaks lasta, siis sellesama tegevuse raames täiesti tehtav asi. Saab ka omal käel tehtud.
Tõsturi tööga olen ise rahule jäänud. Seal peale kokkujooksude/kallete midagi teha lasknud ei ole.
wautzer
postitati 18.03.15 05:09 Tsiteeri
Tänud.. Küsimusele vastus olemas. Broneeri Flamekosse aja..
[PHP: 28.3% - SQL: 71.7%]
