Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi A6(C7) 2.0 TDI chip
Pealkiri: Audi A6(C7) 2.0 TDI chip (Vastuseid: 2 | Vaatamisi: 1711)
mar3cmon
Registreerunud 13.03.15
postitati 13.03.15 13:24 Tsiteeri
Tere kõigile,
Ostsin mõnda aega tagasi endale C7 kerega 2013 aasta Audi A6 2.0TDI(130kW) Multitronic kastiga. Tekkis mõte, et paneks peale Chip-i. Enne kui midagi tegema ja ostma hakkan, siis mõtlesin, et küsin targematelt, et kas kellegil on sellega kogemusi? Kas see võib kuidagi näiteks käigukastile või mootorile kahjustav olla?
Mul sõber paar aastat tagasi pani peale oma Octavia III-le, samuti oli 2.0TDI ja tal töötas asi päris hästi. Kütusekulu läks veidi madalamaks ning minek oli tuntavalt teravam.
Toode mida vaadanud olen:
http://www.racechip.com/chiptuning/audi/a6/c7/2-0-tdi-130kw/index.php
Oleksin väga tänulik tagasiside eest!
postitati 13.03.15 14:00 Tsiteeri
Kui teha tuuningut siis kindlasti normaalselt läbi mootoriaju.
See karbike mis sa vaatad ei ole mingi "chip" vaid paar takistit, mis petavad latirõhu anduri signaali madalamaks. Rahvakeeli tuuningboks.
Selline asi mõjub negatiivselt kõrgsurvepumbale ning reaalset jõulisa sealt ei teki. Ka kütusekulu ei lähe reaalselt madalamaks - kompuuter hakkab ainult numbreid valetama väiksemaks.
Oleme dünos mõõtnud ning kui selline karbike andis juurde vaevu tuntavad 4kw võrreldes originaaliga, siis samal autol korralik tuuning läbi mootori juhtaju 45kw - lisaseadmeid paigaldamata.
Ehk siis - kui midagi teha, siis korralikult. Kas siis meie juures või kuskil mujal, turul on neid pakkujaid küll.
Selle karbi peale ära raha raiska, kõik mis sealt lubatakse on hülgemöla, igasugused megahertsid on ullikeste püüdmiseks, reaalselt on kogu asi tehtav kahe 5 senti maksva takistiga.
Kui selle karbikese nime google-sse panna, siis tuleb sealt kohe väga kiiresti näiteks selline teema:
http://www.northamericanmotoring.com/forums/drivetrain-cooper-s/260857-race-chip-ultimate-somewhat-objective-testing.html
http://www.audiclubsa.org.za/cgi-bin/yabb25/YaBB.pl?num=1398183209/all
Neid näiteid on veelgi - reaalsus on paraku see, et arvestades, kuidas see asi töötab ei saa sealt mingit üle mõõtevea suuruse vahet tulla.
mar3cmon
postitati 13.03.15 14:15 Tsiteeri
Suured tänud tagasiside eest!
Selle mõtte matan maha! :)
[PHP: 29.2% - SQL: 70.8%]
