Pealkiri: Audi A4 3.0Td b7 veakood (Vastuseid: 10 | Vaatamisi: 2305)
Don
Registreerunud 28.05.14
postitati 01.03.15 17:09 Tsiteeri
Tere ehk oskab keegi veakoodist täpsemalt rääkida?
Address 01: Engine Labels: Redir Fail!
Part No SW: 8E0 910 401 E HW: 8E0 907 401 AJ
Component: 3.0L V6TDI G000SG 0020
Revision: --H01--- Serial number:
Coding: 0011911
Shop #: WSC 06325 000 00000
VCID: 2143FB5DF8D2CB1
3 Faults Found:
005495 - Right Engine Mount Solenoid Valve (N145)
P1577 - 001 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 0
Fault Frequency: 90
Mileage: 219122 km
Time Indication: 0
Freeze Frame:
RPM: 714 /min
Torque: 39.0 Nm
Speed: 0.0 km/h
Voltage: 12.54 V
Bin. Bits: 0
Bin. Bits: 0
Bin. Bits: 0
008598 - Oxygen (Lambda) Sensor B1 S1
P2196 - 002 - Signal too High (Rich)
Freeze Frame:
Fault Status: 01110010
Fault Priority: 0
Fault Frequency: 7
Mileage: 227898 km
Time Indication: 0
Freeze Frame:
RPM: 2646 /min
Torque: 0.0 Nm
Speed: 151.2 km/h
Duty Cycle: 1.0 %
Duty Cycle: 194.2 %
(no units): 1.0
(no units): 16.0
004472 - Linear O2 Sensor; Pump Current
P1178 - 000 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 1
Mileage: 228705 km
Time Indication: 0
Freeze Frame:
RPM: 1827 /min
Torque: 74.1 Nm
Speed: 41.4 km/h
Duty Cycle: 15.9 %
Mass Air / Rev.: 323.1 mg/str
(no units): 0.90
(no units): 8.0
postitati 01.03.15 18:15 Tsiteeri
Esimene lihtne, mootoripadi.
Teine veakood viitaks justkui lambdale, aga on olnud ka juhuseid, kus tegelikult on teine viga.
Don
postitati 03.03.15 09:50 Tsiteeri
Siis kui kirjas parem poole see siis ehk kunde poolne?
meelo
Registreerunud 07.01.06
postitati 03.03.15 16:18 Tsiteeri
Algselt postitas: Don
Alati kirjeldatakse sõidusuunas paremat- vasakut poolt.
Kert85
Registreerunud 30.12.14
postitati 03.03.15 16:39 Tsiteeri
Bank 1 samuti kundepoolne.
Don
postitati 03.03.15 19:04 Tsiteeri
Nagu ma aru saan siin neid andureid tal mitu ja see Oxygen (Lambda) Sensor B1 S1 kunde poolne kõige viimane andur?
postitati 03.03.15 19:38 Tsiteeri
Ei ole mitu, kohe peale turbot on. Bank1 ei ole siin tavatähenduses parempoolne.
Don
postitati 04.03.15 11:48 Tsiteeri
Kas tal need mootoripadjad on mingite anduritega?
jõuvanker
Registreerunud 21.03.03
postitati 04.03.15 12:51 Tsiteeri
Ikka anduritega, sisuks on silikoonõli laadne vedelik ;)
postitati 21.05.15 15:43 Tsiteeri
Kui patjade kohta veakoode pole, siis on ikkagi võimalus et mõni läbi on?
Kasti padjad samuti anduritega?
Tundub, et mingi padi on küpse aga niisama ei viitsi ka neid kõiki välja vahetada.
Leopold661
Registreerunud 17.11.04
postitati 21.05.15 19:19 Tsiteeri
Algselt postitas: mkb
Minu autol oli kundepoolne padi läbi(küll a6 aga sama mootor),andis samamoodi veakoodi.
Lõpuks vahetasin ära. Ei saanud aru küll,et midagi muutus. Veakood kadus ainult.
[PHP: 10.2% - SQL: 89.8%]
