Pealkiri: audi a6 3,0 2002 (Vastuseid: 1 | Vaatamisi: 809)
Tanel1988
Registreerunud 26.11.09
postitati 14.02.15 20:58 Tsiteeri
audi a6 3,0 2002
Oskab keegi lahti seletada need koodid?
VAG-COM Version: Release 409.1-US
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56,76
Address 01: Engine
Controller: 8E0 909 559 H
Component: 3.0L V6/5V 0003
Coding: 0011752
Shop #: WSC 48615
4 Faults Found:
17530 - Oxygen (Lambda) Sensor Heating: B2 S2: Open Circuit
P1122 - 004 - No Signal/Communication
17548 - Shareware Version. To Decode all DTCs
P1140 - 004 - Please Register/Activate
16684 - Shareware Version. To Decode all DTCs
P0300 - 001 - Please Register/Activate - Intermittent
16686 - Cylinder 2 Misfire Detected
P0302 - 001 - Upper Limit Exceeded - Intermittent
Readiness: 0010 0001
Address 02: Auto Trans
Controller: 4B0 927 156 EN
Component: AG5 01V 3.0l5V RdW 0808
Coding: 0000001
Shop #: WSC 00000
No fault code found.
Address 03: ABS Brakes
Controller: 4B0 614 517 H
Component: ABS/ESP allrad 1328
Coding: 06397
Shop #: WSC 02325
suured tänud ette :)
Kert85
Registreerunud 30.12.14
postitati 14.02.15 22:56 Tsiteeri
Bank 2 (juhipoolne) teine lambda sensori kütteelement on katkestuses.
Ja silinder 2 jätab vahele vahest.
Teisi koode su arvuti lahti ei ole osanud kirjeldada, aga 16684
16684/P0300/000768 - Random/Multiple Cylinder Misfire Detected
Mis räägib ka, et süttimist pole silindri(te)s olnud.
http://wiki.ross-tech.com/wiki/index.php/16684/P0300/000768
Veakoodid
[PHP: 19.0% - SQL: 81.0%]
