Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - B6 2,5TDI Q automaatkasti jahutus
Pealkiri: B6 2,5TDI Q automaatkasti jahutus (Vastuseid: 1 | Vaatamisi: 842)
marek89
Registreerunud 19.09.12
postitati 25.01.15 10:05 Tsiteeri
Tervist,
Kas keegi teab kuidas b6 2,5 tdi quattro automaadil näeb välja käigukasti jahutus. Kas sellel on eraldi radikas või käib õli läbi mootori radika?
Hakkan õli vahetama värskelt ostetud autol ja oli kunagi kogemus kus B5l sattus automaatkasti õli sisse tosool, kuna õli jahutati auto radikas vms.
Ehk peaks siis vajalikud asjad kontrollima, et sellist jama ennetada.
Tänud.
TarmoValk
Registreerunud 27.06.14
Auto: Audi A6 3.0TDIQ
postitati 25.01.15 15:50 Tsiteeri
Ära ise hakka seal õli vahetama, lase see teha oma ala asjatundjatel. Hõbenool OÜ on selleks pädev koht.
Siin sellest teemasid küllaga, miks seda mitte ise vahetada.
Jahutus käib läbi sama radiaatori. Ainus asi kuidas seda ennetada saad, on vahetus originaali või kvaliteetse radiaatori vastu.
Oli, on ja jääb - Audi
[PHP: 24.2% - SQL: 75.8%]
