Pealkiri: auto ei käivitu, kõik töötab, aga starterit ringi ei jooksuta (Vastuseid: 2 | Vaatamisi: 1625)
risto220
Registreerunud 28.10.10
Auto: audi 100 2.6 quattro
postitati 22.01.15 15:51 Tsiteeri
Thursday,22,January,2015,15:16:57:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WAUZZZ4E23N005504 License Plate:
Mileage: 268320km-166726mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 15 16 17 18 19 1E 25 34 36 37 38 42
46 47 4F 52 53 55 56 57 61 62 65 67 72 76
VIN: WAUZZZ4E23N005504 Mileage: 268320km/166726miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 1010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 1010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 D HW: 4E0 907 560
Component: 3.7L V8/5V G 0070
Revision: 00000000 Serial number: AUX3Z0BD306787
Coding: 0011773
Shop #: WSC 02313 785 00200
VCID: 224B0C03FD3A2A0EA27-8077
No fault code found.
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 A HW: 09E 927 156
Component: AG6 09E 3,7L5V RdW 0100
Coding: 0000001
Shop #: WSC 02802 177 16337
VCID: 204F060BF336381EB43-8075
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 E
Component: ESP 5.7 allrad H29 0400
Coding: 0008597
Shop #: WSC 52201 000 00000
VCID: 2149030FF83C3116BBD-8074
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 K
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0BD306787
Coding: 0410624
Shop #: WSC 26921 136 00231
VCID: D8BFEEEB6BE630DE0C3-808D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
4 Faults Found:
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 04:44:52
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 04:44:52
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 8
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.03.15
Time: 01:41:34
00956 - Key 2
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.03.15
Time: 01:56:30
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 B HW: 4E0 959 760
Component: Sitzmemory BFS H05 0020
Revision: 00000000 Serial number: 5DS 008 795-02
Coding: 4063232
1 Fault Found:
00456 - Control Module for Access and Start Control (J518)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Mileage: 6184 km
Time Indication: 0
Date: 2003.03.15
Time: 01:24:26
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 300II027509452
Coding: 0000002
Shop #: WSC 00000 000 08192
VCID: 3A7BD46375AA42CE9A7-806F
Subsystem 1 - Part No: 4E0 910 609
Component: Bedienteil MMI H41 0010
Subsystem 2 - Serial number: 317AH037508109
Subsystem 3 - Serial number: ˙˙10.01.03˙˙˙˙˙˙˙˙˙˙˙˙&a mp;#729;˙˙˙˙
Subsystem 4 - Serial number: ˙˙˙˙˙˙˙
3 Faults Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:43:13
02003 - Driver Identification Control Module (J589)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:43:22
01319 - Control Module for Distance Control (J428)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 17:56:10
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 011 0240
Revision: 00000011 Serial number: 00000000008815
Coding: 0266443
Shop #: WSC 02447 823 57139
VCID: DABBF4E315EA22CE3A7-808F
5 Faults Found:
01855 - Temperature Sensor for Heated Seat; Left Front (G344)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:34:08
Freeze Frame:
Temperature: 0.0°C
01592 - Air Quality Sensor (G238)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 6
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:34:08
Freeze Frame:
Temperature: -6.0°C
01087 - Basic Setting Not Performed
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:26:12
00716 - Air recirculation Flap Positioning Motor (V113)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Fault Frequency: 10
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.03.14
Time: 07:33:06
Freeze Frame:
Voltage: 10.60 V
Temperature: 0.0°C
(no units): 195.0
(no units): 77.0
Temperature: -78.0°C
01206 - Signal for Duration of Ignition Off Time
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.03.14
Time: 07:33:06
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 A HW: 4E0 907 279 A
Component: ILM Fahrer H11 0070
Coding: 0011102
VCID: 264310139112D62ECEF-8073
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000255
Shop #: WSC 02313
5 Faults Found:
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
01308 - Control Module for Roof Electronics (J528)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
01336 - Data Bus for Comfort System
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 2
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:53
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655
Component: Airbag 8.4E+ H08 0840
Coding: 0431707
VCID: E3C5C90722A0E306691-80B6
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 900 E
Component: KOMBIINSTR. VDO H40 0060
Revision: D05 Serial number: AUDID3C0010172
Coding: 0000003
Shop #: WSC 80152 462 20586
VCID: DCB7F2FB1FDEDCFE28B-8089
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Status: 00000011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 265909 km
Time Indication: 0
Date: 2003.03.03
Time: 20:42:25
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 265 105 D
Component: Heizgeraet H07 0100
Revision: 0000000B Serial number: 00000009006406
Coding: 0000111
Shop #: WSC 20346 133 61029
VCID: 1A3B34E3D56A62CE7A7-804F
1 Fault Found:
01414 - Combustion-Air Blower (V6)
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 HW: 4E0 907 468 A
Component: Gateway H06 0070
Revision: 06 Serial number: 0000302C19026E
Coding: FCFE7BDF2B6504
Shop #: WSC 52201 522 96019
VCID: E5C1D71F2C949D36875-80B0
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.03.15
Time: 01:24:21
00474 - Control Module for Immobilizer
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 4
Mileage: 268328 km
Time Indication: 0
Date: 2003.03.15
Time: 01:24:21
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111
Component: CD-Changer H43 0470
Revision: 00000501 Serial number: AUZ5ZBC1020682
Shop #: WSC 00000 000 00000
VCID: 1C3732FBDF5E1CFE68B-8049
1 Fault Found:
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 7
Fault Frequency: 4
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:02:06
Freeze Frame:
Text: 00000000
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
4 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 04:44:52
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 04:44:52
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.03.15
Time: 01:41:34
00956 - Key 2
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.03.15
Time: 01:56:30
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 C HW: 4E0 907 553 C
Component: LUFTFDR.-CDC H03 4190
Coding: 0015500
Shop #: WSC 32727 134 80397
VCID: 23450907E2202306A91-8076
2 Faults Found:
00778 - Steering Angle Sensor (G85)
008 - Implausible Signal
Freeze Frame:
Fault Status: 11101000
Fault Priority: 3
Fault Frequency: 12
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2015.01.05
Time: 18:10:33
01598 - Drive Battery Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 2
Reset counter: 255
Mileage: 268328 km
Time Indication: 0
Date: 2015.01.05
Time: 18:11:00
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H05 0020
Coding: 4063242
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Mileage: 6184 km
Time Indication: 0
Date: 2003.03.15
Time: 01:24:26
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 T HW: 4E0 919 887 C
Component: MNS ECE H41 1030
Revision: 00000000 Serial number: 305BI037522908
VCID: 3E73D87369826EEEA6F-806B
2 Faults Found:
02445 - Disk Drive Initialization Error
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:44:12
Freeze Frame:
Hex Value: 0x3E5D
Hex Value: 0x979C
Hex Value: 0x386D
Hex Value: 0x0000
02927 - DVD Read Error
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 43
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 04:43:13
Freeze Frame:
Hex Value: 0x3E72
Hex Value: 0x8B87
Hex Value: 0x0A01
Hex Value: 0x0000
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H01 0100
Serial number: 00000234600053
Coding: 0003606
VCID: 1D313FFFC44415F69F5-8048
3 Faults Found:
02104 - Light Detection Sensor (G399)
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 15
Reset counter: 220
Mileage: 262136 km
Time Indication: 0
Date: 2003.02.27
Time: 00:00:00
01370 - Alarm triggered by Interior Monitoring
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 4
Mileage: 0 km
Time Indication: 0
Date: 2003.02.27
Time: 03:21:00
Freeze Frame:
Bin. Bits: 10000000
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 4
Mileage: 262136 km
Time Indication: 0
Date: 2003.03.15
Time: 01:24:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM004 0060
Coding: 0028449
Shop #: WSC 02311 785 00200
VCID: DEB3F8F309C2CEEE46F-808B
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 HW: 4E0 907 289
Component: Komfortgeraet H02 0050
Coding: 0000600
VCID: E6C3D013D192962E8EF-80B3
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H01 0020
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0 035 223 A
Component: DSP-Amp.-High H12 0460
Revision: PROD_01O Serial number: 00000000018384
Coding: 0000026
VCID: 2A5BE423850AF24EEA7-807F
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000038271
Coding: 0010101
Shop #: WSC 20346 133 80621
VCID: 1E3338F3C9420EEE86F-804B
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM004 0080
Coding: 0028449
1 Fault Found:
02111 - Motor for Window Regulator
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 220
Mileage: 268320 km
Time Indication: 0
Date: 2003.02.27
Time: 00:13:52
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000531
Shop #: WSC 02976 202 82039
1 Fault Found:
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 134
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Voltage: 10.25 V
Count: 61
Address 55: Xenon Range
Cannot be reached
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial number: 304E9037523302
Coding: 0000001
VCID: 3169F34FA8DC81962BD-8064
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 G HW: 4E0 919 146
Component: TV analog TUNER H11 0300
Revision: 00000015 Serial number: 00000000000000
Coding: 0001001
VCID: 2541171FEC14DD36C75-8070
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H11 0510
Revision: 00000000 Serial number: 00000000016120
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 1403150017
Coding: 303030393135313035414B56413031343033313530303137
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM004 0080
Coding: 0028449
VCID: DDB1FFFF04C4D5F65F5-8088
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0190
Coding: 0212127
VCID: DFCDC5F70EC8C7E64D9-808A
2 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 11
Reset counter: 5
Mileage: 268328 km
Time Indication: 0
Date: 2015.01.05
Time: 18:10:19
Freeze Frame:
Speed: 0.0 km/h
Temperature: -9.0°C
Error Code: 2048
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01477 - System Switched Off
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 69
Reset counter: 220
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:14:59
Freeze Frame:
Speed: 0.0 km/h
Temperature: -6.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: None
VCID: 55A167DFBCF48DB6975
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM004 0060
Coding: 0028449
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 HW: 4E0 919 283 A
Component: Parkhilfe 8-Kan H07 0030
Coding: 0001008
VCID: E0CFC60B33B6F81E743-80B5
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 268328 km
Time Indication: 0
Date: 2003.02.27
Time: 00:38:38
End ---------------------------------------------------------------------
yanekk
postitati 22.01.15 16:17 Tsiteeri
Kas enam pikemat postitust ei tahtnud teha.
Viga ju kirjas miks ei toimi.
Best ET 12.08 :)
risto220
postitati 22.01.15 16:55 Tsiteeri
lisasin lihtsalt vac-comi logi, aga ise ei jaga seda asja nii palju
[PHP: 40.0% - SQL: 60.0%]
