Tere.
Probleem siis selles et masin ei käivitu (2002.a. A8, 2.8,142kw).
Masinal ees siis järgnevad veakoodid:
P1421: Sec. air inj. valve circ short to ground
P1425: Tank vent. valve short to ground
P1435: Sec. air inj. sys. pump relay circ. short to ground
P1515: Intake manifold changeover valve circuit short to ground
P1530: Camshaft control circuit short to ground
yanekk
postitati 19.01.15 19:11
Algselt postitas: HugoT
Tere.
[PHP: 9.8% - SQL: 90.2%]
