Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890 Eesti Audi Klubi foorum - Kui palju erinevad audi sidurid jõudu kinni hoiavad?
Pealkiri: Kui palju erinevad audi sidurid jõudu kinni hoiavad?
(Vastuseid: 1 | Vaatamisi: 886)
jeff01
Registreerunud 27.11.11
postitati 09.01.15 20:05
oskab keegi ehk rumala jaoks asjad kokku võtta mis variandid on üldse mõeldavad v8 momendi kinni pidamiseks.
mõttes on 2 eri suunda:
1) VR6 228 sidurid....ebay odavad stage 4 korvid peavad ilusate kirjade järgi piisavalt kuid kas seda ka uskuda? ala 580hp oli koguni kirjas kuigi
hobujõude ju sidur ei hoia vaid nmi miinusena tuleks asendada ketta
südamik. Kuni stage 4ni on tundmatute tootjate sidurid olematu hinnaga (kuni 150eur kmpl)
2) miskid 240mm sidurid nagu essidel jne. miinusena häda selles, et 240 ei mahu vist hoorattale.....plussina sobiks vist esside nuut 6se manual
kastiga mis diisli otsast pärit. Tundmatumate tootjate komplektid tundusid vr6 omadest 2x kallimad ja nende jõutaluvus oli väga pessimistlik võrreldes
vr6 omadega.
Kuidas on lugu tegelikult?
2wd kuid slikki peaks pidama....ehk siis vast 4wd koormusega võrreldav.
Ettetänades
yanekk
postitati 09.01.15 20:28
Nu 150 raha eest ei saa ju sa midagi , isiklikult valiks 240mm läbimõõduga
siduri, neid on vajadusel suht palju erinevaid võtta.
Ja osta kohe korralik komplekt, pole ju mõtet kahte korda seda sidurit osta.
Miski ~700.- rahaga peaksid arvestama.
[PHP: 28.9% - SQL: 71.1%]
