Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 98a. A6, 1,9 TDI kaitsmed, paluks autoelektriku nõustamist
Pealkiri: 98a. A6, 1,9 TDI kaitsmed, paluks autoelektriku nõustamist (Vastuseid: 3 | Vaatamisi: 796)
Jumbu81
Registreerunud 15.10.14
postitati 08.01.15 09:14 Tsiteeri
Küsimus siis järgmine, kus asuvad eel kirjeldatud pillil kaitsmed kapoti all? Armatuurlaua küljel olevad üle vaadatud, aga ei leia kapotialt seda karpi üles.
Nimelt juhtus sedasi,et korraga sõidu ajal lõi kõik näidikud nulli, aga auto liikus kenasti edasi ja tuled ning makk töötasid.Koju jõudes(umbes 300m. oli jäänud) süüte välja keerates ning uuesti käivitada üritades, enam ei käivitunud.Sai siis uuritud, aga öeldi,et kui makk ikka töötas, siis peaks genekas korras olema, et arvatavasti läbi mõni kaitse või akujuhe lahti. Akujuhtmed kenasti kinni ja salongis olevad kaitsmed terved.
Jumbu81
postitati 08.01.15 12:14 Tsiteeri
nunii, ise küsin, ise vastan :D Sai siis uuritud ja kõigile teadmiseks, et audidel ei ole peakaitse ja muud "kangemad" kaitsmed kapotiall.Rooli all olev plastikust ilukaitse/polster tuleb eemaldada ja seal need kaitsmed asuvadki.
Aga minu probleemist veel, et kaitsmed olid kõik oki. Ehk on siin mõnd autoelektrikut kes oskaks öelda, kas siis tõesti genekas läbi? Kuniks akus veel voolu oli ja üritasin käivitada, siis muidu üritas genekat ringi vedada küll(lasin naiskal vaadata,samal ajal kui ise käivitasin), lihtsalt jõudu jäi nagu väheks.Ega muidugi geneka ringi käimine ei tähenda, et ta korras, aga kas on kuidagi võimalik omalkäel kodus kontrollida, kas genekas korras?
Oleksin väga tänulik info eest, kui mõni autoelektrit juhtub lugema ja oskab nõu anda, võib ka helistada 53730998.
ahtisaar
Registreerunud 16.10.12
Auto: Audi q7 4.2tdi, Audi coupe 2.6
postitati 08.01.15 12:29 Tsiteeri
Võta töötava mootoriga autol akuklemm maha. Siis ju kohe näha kas laeb või mitte.
yks
Registreerunud 04.05.11
postitati 08.01.15 13:26 Tsiteeri
Algselt postitas: ahtisaar
Vale soovitus. Kui nüüd genekas laeb siis aku eemaldamisel tekib hetkeks suur pinge tõus mis ei ole mitte hea elektroonikale.
Kui muidu aru ei saa vaata kasvõi töötavate tulede tooni, kui ikka kollased siis ei lae. Muidu on selleks tööks olemas multimeeter.
[PHP: 50.5% - SQL: 49.5%]
