Registreerunud 09.06.14
Auto: Audi A4 B5
postitati 17.12.14 16:40
Audi A4 1.8 - 2000 - kr1570
Autoks siis loorberi roheline (LY6R) A4 B5. Pagassi kleepsu järgi sündis siis 2000 aasta märts.
PRCode: 1AC = Anti-lock brake system (ABS)
PRCode: 1BE = Sports suspension/shock absorption
PRCode: 1KD = Disc brakes rear
PRCode: 1LZ = Front disc brakes standard ventilation
PRCode: 1SA = Without additional engine guard
PRCode: 2K1 = Reinforced bumpers
PRCode: 2PV = Leather trimmed sports steering wheel
PRCode: 3L3 = Manual height adjustment for front seats
PRCode: 3NZ = Rear seat bench unsplit backrest split folding
PRCode: 3RA = Without trunk lid or rear doors resp.
PRCode: 4GH = Windshield in heat-insulating glass with sunshield
PRCode: 4K4 = Radio remote controlled central locking
PRCode: 4R2 = Power windows front mechanical window regulators rear
PRCode: 4UE = Air bag for driver and front seat passenger
PRCode: 4X3 = Side air bag front with curtain air bag
PRCode: 5D1 = Carrier frequency 433.92 MHz-434.42 Mhz
PRCode: 5MF = Decorative aluminum inserts
PRCode: 5RQ = Right exterior mirror: convex
PRCode: 5SL = Left exterior mirror: aspherical
PRCode: 6R2 = Leather gearshift boot
PRCode: 6XD = Exterior mirrors: electrically adjustable/heated
PRCode: 7X0 = Without park distance control
PRCode: 8GD = Alternator 90A
PRCode: 8JH = Ellipsoidal headlight for driving on the right
PRCode: 8Q1 = Headlight-range adjustment
PRCode: 8Z5 = Not hot country
PRCode: C4X = Alloy wheels 7J x 16
PRCode: D1A = 4-cyl. gasoline engine 1.8 L/92 kW 20V EU 3D base engine is T5Z
PRCode: J1P = Battery 220 A (44 Ah)
PRCode: Q1D = Sports front seats
PRCode: T5Z = 4-cylinder gasoline engine 1.8 L unit 058.B
PRCode: U2A = Instrument insert with km/h speedometer radio-controlled clock tachometer and trip odometer
kr1570
Auto: Audi A4 B5
postitati 17.12.14 17:15
Hetkel auto küsib õli ja filtrite vahetust. Kuna jõulud tulekul siis teeb ühe odavama õli ja filtrite vahetuse siis kannatab uue aastani viisakalt.
kr1570
Auto: Audi A4 B5
postitati 23.12.14 19:30
Selline probleem, et on ees selline märk ja pagassi osa vilgub. Milles võib viga olla ja kuidas seda kõrvaldada?
zander91
postitusõiguseta
Auto: audi a4 b7 3.0Q
postitati 23.12.14 19:54
Algselt postitas: kr1570
Järelikult pagasiluuk lahti ? Teine varjant mõni juhe ehk haiget saand ja andur või lukk annab vale infot ,juhul kui pagasiluuk on sulgund/suletud.
kr1570
Auto: Audi A4 B5
postitati 23.12.14 23:27
Luuk suletud, hakkas sõidu aeg vilkuma sai kontrollitud luuki ja uuesti kinni pandud aga ei midagi. Korra sõidu aeg kadus ära kuid siis hakkas jälle
pihta. Eks hakkan siis neid juhtmeid üle kontrollima.
[PHP: 27.1% - SQL: 72.9%]
