Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Süütepool
Pealkiri: Süütepool (Vastuseid: 6 | Vaatamisi: 1176)
j6ud
Registreerunud 16.04.12
postitati 13.12.14 16:13 Tsiteeri
Süütepool
Audi A4 avant 2002.a 2.0 bens (96kW) süütepool 2 aastaga läbi.
Kas on loogiline?
Kaks aastat tagasi sai Forssi esindusest ostetud järjest süütepoole, kõik neli sai ära vahetatud, üks maksis ~50EURi.
Kas võib milleski muus viga olla või tuleks kuskilt mujalt osta?
Gunnark
Registreerunud 27.10.09
postitati 13.12.14 16:30 Tsiteeri
Algselt postitas: j6ud
Kas on loogiline?
Suht laialt levinud probleem, ka kahe aastaga võimalik. Endal maksis ca 30 nii B8-l kui B6-l.
j6ud
postitati 13.12.14 16:47 Tsiteeri
Kaks aastat jah, selle ajaga ca 20000 km ainult sõidetud
Gunnark
postitati 13.12.14 16:55 Tsiteeri
Mina olen täheldanud, et just selliste dibiilsete külm/soe vahetuvate ilmadega annavad nad lambist saba(viimase kuuga läks mul kaks), ammu sai loetud ka,et b6 algusaegade süütepoolid olid nö kehvad aga jah, ma pean seda antud autode paratamatuseks, ilmselt kui süsteem annab mingi tõrke, siis esimese asjana põleb süütepool sellepärast läbi.
j6ud
postitati 14.12.14 14:08 Tsiteeri
Sai täna proovitud süütepoole ja küünlaid vahetada, kuid tulemusteta. Lasin sõbral arvuti järgi panna ja andis veakoodid 16686 ja 16684. Süütepoolid ja küünlad paistavad korras olevat, kust järgmisena viga otsida?
differ.ee
Registreerunud 10.10.13
postitati 14.12.14 14:14 Tsiteeri
Silindrite surved üle mõõta? Pihusti ringi tõsta mõne teise silindriga?!
j6ud
postitati 15.12.14 15:21 Tsiteeri
Kas mingi klapp võib kinni olla? Täna üks remondimees vaatas veits autot ja silinder hakkas tööle pärast paarutamist. Homme remondimehel rohkem aega, vaatab täpsemalt.
Kas mingit kütuselisandit kasutada, et tulevikus selliseid asju vältida?
[PHP: 51.6% - SQL: 48.4%]
