Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 2.5tdi jõudu pole
Pealkiri: 2.5tdi jõudu pole (Vastuseid: 45 | Vaatamisi: 4834)
KKaaleste
Registreerunud 06.10.10
postitati 04.12.14 18:35 Tsiteeri
2.5tdi jõudu pole
Autol v6 2.5tdi 110 kw..
Mootor käib ilusti, aga minekut ja jõudu nagu ei ole.
Millest alustada? Turbo lõdvikud pööret andes lähevad kõvaks, voolikud sai üle vaadata, turborõhu andur tundus nagu täidaks ka oma ülesannet. Kas võib olla asi õhulugejas? Millest muidu aru saada, et katid umbes?
Igasugune abi teretulnud..
yanekk
postitati 04.12.14 19:34 Tsiteeri
Algselt postitas: KKaaleste
Millest alustada?
Kui visuaalselt nagu kõik korras, siis ikka saba koos arvutiga.
Best ET 12.08 :)
raidoaudics
Registreerunud 16.11.06
postitati 04.12.14 19:50 Tsiteeri
Oskan sind kindlasti aidata viljandis.
KKaaleste
postitati 04.12.14 20:38 Tsiteeri
Kahjuks ma Tallinnas.
KKaaleste
postitati 05.12.14 17:35 Tsiteeri
Täna vahetasin kütuse filtri ära ja ei midagi.
Arvuti näitas kahte viga:
misfire do lack of fuel
heat temp sensor
Mis edasi??
KKaaleste
postitati 05.12.14 18:44 Tsiteeri
appi
postitati 05.12.14 19:05 Tsiteeri
1. Õigekiri
2. Kui keegi tunnikese jooksul ei vasta, et tasu appi hakata kisama.
teet82
Registreerunud 17.11.13
postitati 05.12.14 19:06 Tsiteeri
Elementaarsed asjad tuleks ikka arvutiga üle vaadata alustuseks, näiteks jälgida turborõhku ja õhulugeja näitu proovisõidul, neid asju oskavad arvatavasti päris paljud kontrollida siin.
Kui on automaatkastiga, siis see muudab kõvasti uimasemaks selle auto, polegi midagi tahta väga. Lisaks võivad nukkvõllid kulunud olla jne..
KKaaleste
postitati 05.12.14 19:14 Tsiteeri
See on automaatkastiga.
Ja mul on eelnevalt olnud selline, ma tean kuidas nö minek ja palju jõudu peaks olema.
Üle 100 km/h kiirendada siis see võtab ikka omajagu aega ja no sõita ongi pmst nii nagu sõidaks ilma turbota!
Kas leidub siin keegi kes saaks aidata? Abi ei jää tasustamata!!
KKaaleste
postitati 05.12.14 19:17 Tsiteeri
Algselt postitas: mkb
1. Õigekiri
1. Õigekiri okei, minu viga.
2. Pole veel kisama hakanudki.
KKaaleste
postitati 05.12.14 19:34 Tsiteeri
Ja selle nukkade asja jätaks hetkel ehk viimaseks asjaks..
Kui tuleb välja,et tõesti selles asi.. siis vahetab ära.
ferdinand
Registreerunud 17.01.03
Auto: 400,401,969
postitati 05.12.14 20:55 Tsiteeri
Mina arvan, et kui keegi väidab, et oskab kindlasti aidata, siis ei ole Viljandi liiga kaugel sõitmiseks.
Omaette küsimus on muidugi see, et kui tõsiselt sellist lubadust võtta tasub.:D
Mina näiteks küll ei oska midagi pakkuda kui mingitki infot ei pritsita, st soovitaks samamoodi esimese asjana ikka saba järgi ühendada, veel parem kui keegi oskaks diagnostika teha.
KKaaleste
postitati 05.12.14 21:15 Tsiteeri
Arvuti peale nende kahe vea ei näidanud!
Auto on jõuetu, mootor tiksub nagu kell, turbo töötab, gaasi andes kuskil nagu podiseks veel midagi. Mingi imelik hääl kuskilt tuleb, aga ei saa aru kust. Esmaspäeval proovin teist õhulugejat peale, eks siis saab jälle edasi minna. Küttekulu tundub ka kuidagi suur!
Samas tundub, et see õhulugeja on hiljuti vahetatud, aga jah.. ei tea...
acerbis
Registreerunud 24.11.14
postitati 05.12.14 21:21 Tsiteeri
Kas musta lööb tagant ? Turbo rõhku oled mõõtnud ?
KKaaleste
postitati 05.12.14 21:28 Tsiteeri
Turbo rõhku ei ole veel mõõtnud. Teen seda esmaspäeval. Musta ei tule tagant grammigi.
raidoaudics
postitati 05.12.14 23:20 Tsiteeri
Vaata omal vaakumid üle kõik. Kas on ikka õieti koos voolikud ?
postitati 05.12.14 23:54 Tsiteeri
Kui tasustatud saab, siis võib ju vaadata.
Aeg kirja ja otsib vea üles, ei midagi keerulist.
ferdinand
Auto: 400,401,969
postitati 06.12.14 20:24 Tsiteeri
Õhulugeja on sellisel masinal üks viimastest millega tegeleda, selle korrasolekut on ka lihtne kontrollida.
jsv
Registreerunud 12.04.13
Auto: a6 avant 2,5 tdi quattro ,00
postitati 09.12.14 22:30 Tsiteeri
Pista korra egr-i ja turbo vaakumid ringi. Äkki vahetusse läinud.
elu on elamiseks
KKaaleste
postitati 10.12.14 06:25 Tsiteeri
Proovin. Prj juurde ka aeg pandud, eks näis mis saab.
KKaaleste
postitati 11.12.14 07:26 Tsiteeri
Vaakumid kôik nii nagu peab.
raidoaudics
postitati 11.12.14 20:52 Tsiteeri
Käisid Prj-i juures ära ?
KKaaleste
postitati 12.12.14 08:02 Tsiteeri
Auto seal, peale lõunat ehk saab kätte.
Erki23
Registreerunud 02.07.10
Auto: quattro
postitati 13.12.14 20:03 Tsiteeri
Kas probleemile leiti lahendus?
KKaaleste
postitati 13.12.14 22:51 Tsiteeri
Algselt postitas: Erki23
Sain auto reedel kätte.
Peale proovisõitu olevat tekkinud mootorisse klõbin sisse. Viga siis kaante all. Kõik muu toimis.
Järgmine nädal lähevad kaaned maha, vaatab mis suprise seal sees ootab. Arvatavasti läheb sinna kõik uus. Olin sellega põhimõtteliselt ka arvestanud, niiet ei midagi kosmilist. Eks siis tuleb veel sama töö käigus teha ka rihmavahetus jne..
[PHP: 22.1% - SQL: 77.9%]
