Pealkiri: Audi a8 puldi tutvustamine. (Vastuseid: 9 | Vaatamisi: 1325)
Habemik
Registreerunud 17.06.07
Auto: Audi A4, Audi B4 1.9, Audi a8 2,5
postitati 26.11.14 14:49 Tsiteeri
Tervist. Oskab keegi öelda kuidas saab autole puldi uuesti selgeks teha peale keskluku pumba vahetust? 2002 a
maido123
Registreerunud 23.01.11
Auto: A8 3,7 2002a quattro
postitati 27.11.14 16:39 Tsiteeri
https://www.youtube.com/watch?v=lca6P9HBjw0
Habemik
postitati 27.11.14 18:09 Tsiteeri
Tänud. Seal videos vist kaks võtit kasutusel?. Mul ainult üks võti. Kas selleks läheb kahte vaja?
maido123
postitati 27.11.14 18:41 Tsiteeri
Ilmselt ei lähe, aga võin ka eksida. Proovi järgi.
Habemik
postitati 27.11.14 19:24 Tsiteeri
Süüdet ei saa siis ju sisse panna ja samal ajal ust lukustada :D
Gunnark
Registreerunud 27.10.09
postitati 27.11.14 19:29 Tsiteeri
Algselt postitas: Habemik
Proovi:
1 - put driver window down.
2 - insert key in door lock
3 - twist to unlock and hold in position.
4 - with other paw unlock the car using the door panel button.
5 - release and remove key from door.
6 - test remote.
Või nii:
a. Open the vehicle mechanically with the key.
b. Insert the key into the ignition switch and switch to the ON position.
c. Switch the ignition OFF again.
1. If the synchronization does not help, check the battery of the remote control. The battery voltage must be 3.0 V or higher.
2.If the remote battery voltage is below 3.0 V, replace the battery and perform synchronization again.
3.Check whether there are any interfering senders nearby.
4.Check whether there are any interfering senders in the vehicle.
5.If interference was responsible for the condition, explain this to the customer.
Või nii:
istu autos
Close door,
Put key in ignition and turn to 'On' (Not Start)
You have 10 seconds to press and release either the Open or Close button on the Fob.
Door locks should cycle to show it has reprogrammed
Gunnark
postitati 28.11.14 05:16 Tsiteeri
Algselt postitas: Gunnark
Proovi:
6 - test remote.
Või nii:
Või nii:
istu autos
Close door,
Oli kasu?
Habemik
postitati 28.11.14 05:58 Tsiteeri
Eile ei jõudnud vaadata, eks õhtu proovin ja annan kindlasti teada ;)
Habemik
postitati 28.11.14 10:53 Tsiteeri
Ei taha kuidagi pulti sõbraks võtta. Puldi patareid uued. Ise mõtlesin et lasen ühe võtme järgi teha , et saaks süüte sisse panna. Ehk siis suurem tõenäosusu et hakkab ka tööle.
Gunnark
postitati 28.11.14 11:05 Tsiteeri
Nu siis vaja rohkem googeldada veel, proovi kaabliga voi linnaautosse voi kuhugi kus Viljandis vag autode votmeid programeeritakse.
[PHP: 16.2% - SQL: 83.8%]
