Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Heitgaasid üle normide
Pealkiri: Heitgaasid üle normide (Vastuseid: 41 | Vaatamisi: 5141)
marekfeis
Registreerunud 08.01.13
Auto: A6B5 1.9TDI
postitati 25.11.14 14:17 Tsiteeri
Oskab keegi aidata? Täiesti uued katid alla pandud, seda kinnitas tehnoülevaatuse kutt ning vastav paber koos ostutšekiga.
Millest see viga võib tulla? Kuidas parandada?
http://s30.postimg.org/6dp8vxsdd/10816008_393639317468895_596259743_n.jpg
tl470487
aeg maha
Registreerunud 06.07.11
postitati 25.11.14 14:23 Tsiteeri
Diagnostika teema. Kahtlustada võib, et lambda andur ei tööta aga pimesi vahetada ei soovita ehk vaja eelnevalt ikka lambda väärtusi/tööd vaadata. Kütuse segu koostamisel osaleb ka veel muid komponente.
postitati 25.11.14 14:24 Tsiteeri
Algselt postitas: tl470487
Kui lambda andur ei töötaks, siis oleks lambda näit ju paigast ära.
Paberil ilutseb lambda 1.017.
Mõned variandid:
1) Mootoris kompressioon olematu.
2) Katid täiesti külmad, soojaks sõitmata
3) Katid valesti paigaldatud (mootorist liiga kaugele, mitte originaalasendisse).
4) Katid ebakvaliteetsed B osad või ei sobi sellele mootorile (väiksed, liiga suure sõelaga jne).
jsv
Registreerunud 12.04.13
Auto: a6 avant 2,5 tdi quattro ,00
postitati 25.11.14 14:25 Tsiteeri
Üle normide lähevad näidud ka siis kui väljalaskes kuskil mõra või auk on. Mul oli kunagi ühel Omegal väljalaske kollektoris vaevu märgatav mõra ja sellest piisas, et ülevaatust ei läbinud. Võib olla ka mõni kinnitus või tihend. Tegelt on veel palju asju mis heitgaasid üle normide ajavad. Alustades küünaldest kuni anduriteni välja. :D
elu on elamiseks
marekfeis
Auto: A6B5 1.9TDI
postitati 25.11.14 14:26 Tsiteeri
Diagnostika teema.
Mul on autol kaabeldused (USB otsad, VAG) ilusti salongi veetud. Mis programmiga sellele USBle ligi saab?
Mingid mikromootori katalüsatorid, mis isegi tühikäigul ei suuda CO-d alla saada? CO peaks ikka olema mingi suurusjärk väiksem, kui pildil, isegi tühikäigul, kui nõuetele vastab.
Fugitive
Registreerunud 12.02.06
postitati 25.11.14 14:28 Tsiteeri
Oletan, et tegemist on 2,6 V6'ga, ilmselt ongi lambdad väsinud, ei reageeri piisavalt kiiresti vms. Oli kunagi sama mootoriga auto ja sama probleemiga, said uued lambdad pandud ja oligi korras.
postitati 25.11.14 14:29 Tsiteeri
Algselt postitas: Fugitive
Lambda näit paigas ju :)
teet82
Registreerunud 17.11.13
postitati 25.11.14 20:39 Tsiteeri
Lambda näit heitgaasianalüsaatoril ja lambda andur on täiesti erinevad asjad, seal ei ole otsest seost.
Kui on pandud mingid odavad universaalsed katalüsaatorid, siis ega nendega lihtsalt testi ei läbigi. Olen neid ka ise paigaldanud koos uute lambdadega ja ikkagi peab meeletult kaua gaasi peal hoidma ja kuumaks ajama, et test läbida. Pigem sõltub see TÜV tegijast, et kaua ta mässata viitsib.
Ja lambda andur peab reaalselt töötama piisava kiirusega, see lambda näit võib ka katkise anduriga paigas olla, see ei puutu asjasse.
Fugitive
postitati 25.11.14 21:11 Tsiteeri
Algselt postitas: prj
Võta üks vanakooli V6 või suvaline teine auto, pista gaasianalüsaatori ots summutitoru sisse, võta kapoti all lambda pistikud lahti ning vaata mis lambdaväärtuse gaasianalüsaator sulle näitab:) Olen lahtiühendatud lambdadega ülevaatusel käinud, lambda näit oli sama mis siin väljatoodud paberil.
marekfeis
Auto: A6B5 1.9TDI
postitati 26.11.14 07:29 Tsiteeri
Sebisin reedeks endale kuti, kes kaabli autole taha viskab, siis vaatab millega tegu.
Vahepeal vahetan uuesti õli ja filtri ära ning viskan uued küünlad ja õhufiltri sisse. Käin kanali pealt ka läbi, otsin mõne võimaliku prao sumpsist. Äkki aitab. Katte ma ei tahaks küll uuesti vahetada, tutikad all, maksavad liiga palju.
Fugitive
postitati 26.11.14 07:45 Tsiteeri
Sellele mootorile ainuõige universaal katalüsaator on Laki Autost metallkärjega sport kat. Keraamilise kärjega üniversaalid kestavad heal juhul paar aastat ja saad jälle vahetada.
marekfeis
Auto: A6B5 1.9TDI
postitati 26.11.14 18:21 Tsiteeri
Igastahes plekkisin 36€, et oma katid üle kontrollida - nagu mainitud, täiesti korras.
Vahetasin uuesti õli ja filtrid ning viskasin uued NGK küünlad ka sadulasse. Sumpsi ühenduskohas oli ka väike leke, tihendasin ära. Kuna korduvülevaatus on tasuta peaks ehku peale proovima äkki midagi aitas.
IBTL - Keegi seda 95 Nitrot, vms bena see on, kasutanud on? Naised saunas rääkisid, et pidavat ka aitama heitgaaside numbrinäitu madaldama.
Siim
Registreerunud 26.04.10
postitati 26.11.14 19:06 Tsiteeri
98 ja enne ÜV 10-15 km 4-5000 rpm and no problem.
marekfeis
Auto: A6B5 1.9TDI
postitati 26.11.14 20:27 Tsiteeri
Algselt postitas: Peetrus
Ei saanud aru.
Dr.Rammstein
Registreerunud 09.04.10
postitati 26.11.14 20:30 Tsiteeri
Algselt postitas: marekfeis
Ei saanud aru.
Millisest lause osast sa aru ei saanud? Sellest et 95 Nitro asemel pane 98 sisse, või sellest, et enne ülevaatusele minekut sõida katalüsaatorid korralikult kuumaks, et neist kasu ka midagi oleks.
marekfeis
Auto: A6B5 1.9TDI
postitati 26.11.14 20:40 Tsiteeri
Issand ma ei saanud ta sõnastusest aru, milles probleem? Tänan, et puust ette ja punaseks võõpasid.
marekfeis
Auto: A6B5 1.9TDI
postitati 27.11.14 13:29 Tsiteeri
Tegin nagu Peetrus ütles, madalamaks läks, kuid tulemus järgnev. Lasin mingisugust kütsilisandit ka ennem viiele liitrile 95 peale, sõitsin otsa ja panin 98 peale.
http://i.imgur.com/wLS1Llv.jpg
Kusjuures imelik on see, et leidsin eelmise aasta paberi üles ning selle järgi pole probleeme üldse olnud. Ma ei saa aru millest selline vahe järsku.
http://i.imgur.com/upXbSP5.jpg
PTC
Registreerunud 20.08.12
Auto: A6 55 TFSI e
postitati 27.11.14 13:52 Tsiteeri
Kas kõrge CH pigem mittetäielikku põlemist ei näita? St küünlad, juhtmed jms.
marekfeis
Auto: A6B5 1.9TDI
postitati 27.11.14 13:56 Tsiteeri
CH näitab põlemata kütust jah, aga kuna mul on uued küünlad, õli ja õhufilter ning õli ise, siis ma ei taipa, miks see CH tase kõrgemaks läks.
PTC
Auto: A6 55 TFSI e
postitati 27.11.14 14:12 Tsiteeri
Küünlad tahmased ei ole? Mootori mass poollahti pole?
marekfeis
Auto: A6B5 1.9TDI
postitati 27.11.14 14:25 Tsiteeri
Küünlad täiesti puhtad, värvuse järgi näitab väga head põlemist. Mootori massiga tegelen pärast tööd.
Kaabli sai varem, kui arvasin, taha - arvuti järgi kõik ok. Klots täiesti koos.
tl470487
aeg maha
postitati 27.11.14 14:27 Tsiteeri
Sest kütusesegu koostis on vale.
Mõlemat lambdat võiks graafiliselt vaadata, ja küsiks mis temp. mootori aju näeb kui mootor soe?
marekfeis
Auto: A6B5 1.9TDI
postitati 27.11.14 14:30 Tsiteeri
Tra oleks mingi vana risla, mille eest pole hoolt kandnud, teeks ammu mustalt ära, aga krt auto liiga armas mulle. :mad:
[PHP: 30.5% - SQL: 69.5%]
