Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - audi 80 b3 ei lähe pele nädalat seismist käima
Pealkiri: audi 80 b3 ei lähe pele nädalat seismist käima (Vastuseid: 3 | Vaatamisi: 1045)
Martin.M
Registreerunud 14.01.14
Auto: Audi 80 b3
postitati 14.11.14 19:39 Tsiteeri
Tervist, mure siis selline, et kuna ilmad on jahedamaks läinud ei lähe auto enam peale nädalat seismist käima. Enne läks ka vaevaliselt peale pikka seisu kuid nüüd ei käivitu enam üldse.Igapäevaselt käivitadea käivitus probleemideta. Annad starterit, mängid gaasi pedaaliga, nagu lubab ja läheks aga jääb tööle nagu töötaks ühe peaga ning sureb välja. Vahetatud hiljuti mootori rihm, õlid, filtrid, temp andur, küünlad ja küünla juhtmed. Ei oska nagu viga kuskilt otsida enam. Mootoriks on autol 1.6 karburaator.
Loodan, et teema väga segane ei tulnud. :)
postitati 14.11.14 20:17 Tsiteeri
No aga kas mootorit jõuab ringi ajada normaalselt? Pole aku tühi ega starter elupäevi lõpetamas?
Muidugi ega need probleemid peale rihmavahetust hakkanud? Võibolla rihmamärgid paigast, süüde vale
ülks
Registreerunud 04.12.04
postitati 14.11.14 20:23 Tsiteeri
Vaata jagaja kaan ja rootor ka üle.
www.teemetünni.ee
Martin.M
Auto: Audi 80 b3
postitati 15.11.14 09:07 Tsiteeri
Viga leitud. Asi oli lahtises temp anduri juhtmes. Tänud kõigile, kes head nõu andsid.
[PHP: 26.0% - SQL: 74.0%]
