Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890 Eesti Audi Klubi foorum - küsimus audi a4 b5 kohta.
Registreerunud 17.09.14
Auto: Audi a4 b5 1.8 92kw
postitati 14.11.14 11:06
Selline küsimus siis et kas keegi oskab öelda miks antud autol sumbutist vett välja pritsib ? Jahutusvedelik ei kao kuhugi ja ükski teine vedelik ka
mitte. Mootoriks 1.8 92kw ADR
Dr.Rammstein
Registreerunud 09.04.10
postitati 14.11.14 11:16
Kuna euronormid on nii rangeks aetud siis mootorist väljuv heitgaas peab olema puhas vesi. Seega on sul auto nõuetele vastav
Nali naljaks. Täiesti normaalne nähtus, eriti kui sõidad autoga vähe. Tean inimesi kes on viimase püti lõppu teinud augu, et vesi välja tuleks.
joost
Registreerunud 16.09.14
postitati 14.11.14 14:29
Sest et CH + O2 = H20 + CO2
(kütus + hapnik = vesi + süsihappegaas)
pure23
[PHP: 31.7% - SQL: 68.3%]
