Pealkiri: Tagumisteklotside vahetus audi c6 (Vastuseid: 15 | Vaatamisi: 2113)
TurboSlava
Registreerunud 09.03.11
Auto: 5X Audi 100 sedaan c4
postitati 14.11.14 09:12 Tsiteeri
Tere sooviks ise vahetada audi c6 tagumisteklotse. On vag com olemas. Äkki keegi oskaks tutvustada , kust kohast saab lasta kolb sisse ennast keeraks?
www.street.ee
Autoüritused.
Rain573
Registreerunud 17.09.05
postitati 14.11.14 09:15 Tsiteeri
Algselt postitas: TurboSlava
Vb leiad siit ühteist link
mtaudi
Registreerunud 26.02.07
postitati 14.11.14 09:18 Tsiteeri
Ja seda osa, kus on kästud akulaadija selle operatsiooni ajaks autoga ühendada, ei ole suusoojaks kirjas. Ilma selleta see funktsioon ei tööta. Soovituslik on ennem supordi lahti keeramist ka pistik eemaldada, et kogemata või halbade asjade kokkulangemisel suport ennast lahti tagasi ei keeraks.
Gunnark
Registreerunud 27.10.09
postitati 14.11.14 09:22 Tsiteeri
Siit:
http://www.audiworld.com/forums/a6-s6-c6-platform-discussion-58/diy-rear-brake-pads-2785592/
Allolev on Elsast:
Special tools and workshop equipment required
t Torque wrench -V.A.G 1331-
t Torque wrench -V.A.G 1332-
t Vehicle diagnosis, testing and information system -VAS 5051B- or -VAS 5052-
t Interchangeable head -T40065-
t Interchangeable head -T40066-
t Piston resetting appliance -T10145-
Removing
Notet Mark brake pads when removing them if they are to be reinstalled. Fit in same position when installing otherwise uneven braking will be caused.
t It is recommended to apply the electronic parking brake again after driving long distances.
t The clearance between brake disc and brake pad is adjusted automatically approx. every 1000 km, unless the EPB is operated while covering this distance.
t The brake disc is secured with a cross-head screw.
– Raise vehicle.
– Remove wheels.
Caution
On vehicles with ceramic brakes the wheel must not be allowed to drop onto the brake disc. This would cause irreparable damage to the disc. Screw two assembly pins into the wheel bolt holes when removing and fitting a wheel. Insert the long assembly pin into the top hole.
– With ignition switched off, connect vehicle diagnosis, testing and information system -VAS 5051B- or -VAS 5052- to 16-pin diagnostic connector in vehicle and select parking brake with “address word” 53.
Notet Ignition on
t Parking brake released
t Coding checked and rectified if necessary
t Fault memory interrogated, indicated faults eliminated and fault memory erased.
Indicated on display of VAS 5051:
– Select function “53 - Parking brake”.
– Select function “04 - Basic setting”.
t The prompt to enter a display group appears in display zone -1-.
t Display zone -2- shows a keypad.
When installing new or used brake pads
– Enter “7” as “display group number” via the keypad in display zone -2- and confirm entry with the "Q key" (resetting piston).
– Press the green arrow button (bottom left) to exit from the input mask.
Notet Ignition off.
t The brake disc is secured with a cross-head screw -arrow-.
– Remove wheels.
– Remove securing bolts from brake caliper housing, when doing this counter-hold on guide pins.
Notet Do not unplug connection of actuator motor or brake system, otherwise a fault will be registered in the memory.
t Do not apply tension on brake hose or electrical wiring.
– Move brake caliper clear to one side or tie up on body.
– Remove brake pads.
– Remove guide clips.
– Press brake piston back.
Notet On vehicles with a 16" brake system, the brake carrier must be removed prior to removing the brake discs
t Check brake discs and renew if necessary.
Removing the brake carrier:
– To remove the bottom bolt connection of the brake carrier use interchangeable head -T40065- on the left side and interchangeable head -T40066- on the right side.
Installing
Only use methylated spirits to clean the brake caliper housing.
– Insert pad retaining springs.
– Fit brake pads.
– Ensure that the brake pads are located correctly in the pad retainers -arrows-.
NoteThe next work step only applies to vehicles on which the brake carrier needed to be removed.
– Use interchangeable head -T40065- or interchangeable head -T40066- to install the lower bolt connection.
– Secure brake caliper housing with new self-locking bolts.
NoteThe repair kit includes four self-locking hexagon bolts which must be installed in all cases.
– Enter “6” as “display group number” via the keypad in display zone -2- and confirm entry with the "Q key". (Moving piston to original position)
Caution
– Install wheels →Wheels and tyres; Rep. Gr.44.
– Check brake fluid level and top up if necessary.
PTC
Registreerunud 20.08.12
Auto: A6 55 TFSI e
postitati 14.11.14 11:02 Tsiteeri
Ilma akulaadijat ühendamata seisupiduri lahtilaskmine samuti töötab. Pidurikolvi tagasisurumisel tasub vaadata et näiteks selleks kasutatav pitskruvi kolvi suhtes võimalikult otse oleks (veidi keeruline kuna seisupiduri servo jääb ette) muidu võib kolb viltu minna. Ja pistikuid ma pigem ei puutuks kuna nende lahtisaamine on suurem jama kui sellega kaetav risk.
siim1314
Registreerunud 12.04.11
Auto: A6 2006 171kw
postitati 14.11.14 11:43 Tsiteeri
Youtubes olen ka kindlasti õpetust näinud kuidas kõike teha, VCDSi teema oli ka olemas seal videos, aga hetkel kiiruga ei õnnestunud kahjuks leida. Kui õigesti mäletan siis oli venekeelne pealkiri.
mtaudi
postitati 14.11.14 11:47 Tsiteeri
Algselt postitas: PTC
Ära Sina küll palun C6 tagapiduritele oma kätt külge pane - selline sõbralik soovitus.
Seisupidurit EI SAA täielikult avada ilma kaabli ja akulaadijata (jah - otse vool peale lasta, saab, kuid sellega kaasnevad muud ohud). Salongi nuppu kasutades ei avane piisavalt ja uute klotsidega enam paika ei lähe. Sellel autol ei ole suurt midagi tagasi suruda ja pitskruvid võib rahuliku südamega sahtlisse jätta. Kui ei kasutada õigeid võtteid ja kaabli asemel seda salongi nupuga avatakse ja siis pitskruvidega kallale minna, võib pärast poodi uute supordite järgi minna. Pistikud käivad väga kerge liigutusega küljest ära ja tagasi külge ning mingit jama seal küll ei ole.
PTC
Auto: A6 55 TFSI e
postitati 14.11.14 12:18 Tsiteeri
Ilmselgelt pole eelnev postitaja C6 tagaklotse ise vahetanud. Gunnark toodud link näitab ilusasti kogu protsessi samm sammult ära. Ilma VCDS kasutamata ei saa loomulikult klotse maha. Kuid seisupiduri servo vabastamine läbi VCDS'i ei tõmba kolbi ennast tagasi.
Eero
Registreerunud 29.10.04
Auto: B2 2dq
postitati 14.11.14 12:25 Tsiteeri
Ma olen kahel C6'l vahetanud (tõsi küll ise tegin ainult selle arvutiga seadistamise osa) ja mingit akulaadijat ei ole vaja olnud.
Gunnark
postitati 14.11.14 12:30 Tsiteeri
Lingil on kasutatud akulaadijat...elsawin-is mitte, ilmselt on protsess tehtav mõlemil moel. Punkt.
mtaudi
postitati 14.11.14 13:13 Tsiteeri
Koguni kolmel erineval olen teinud seda. VCDS-i kasutades ei rakendu kolvi sissetõmbamise funktsioon, kui laadijat taga ei ole. Gunnarki lahenduses on kasutatud ka septsiaalseid vahendeid ning elektroonilisi abivahendeid, mis ei pruugi vajada eraldi laadija ühendamist, kuid VAG-COM kaablit ja tavatööriistu kasutades peaks see olema möödapääsmatu protsess.
Eks seda võib erinevalt teha ja katsetada, kuid mingit kodukootud lahendust küll soovitada ei julgeks inimesele, kes esimest korda seda teeb. Olen ühte meest juba mööda linna oma rikutud supordiga ringi sõidutanud, kes manualile sülitas ja ise katsetas - tulemuseks oli välja lupsanud pidurikolb ja suur mure, mis edasi teha.
Tahtsin lihtsalt abiks olla ja ennetada probleeme, kuna olen neid liiga palju juba näinud.
Leopold661
Registreerunud 17.11.04
postitati 14.11.14 14:11 Tsiteeri
Laadija järgi ja VCDS-iga saab asi tehtud,milleks leiutada teistmoodi kui pärast võib see nali kordades rohkem maksma minna.
Vahetad klotsid ära ja peale seda saab teha mingi testi ka veel,et asi õige oleks.
PTC
Auto: A6 55 TFSI e
postitati 14.11.14 14:54 Tsiteeri
Siin on kirjutatud miks on laadijat tarvis tagaklotside vahetusel: Milleks vaja akulaadijat
Ja siin on antud veel üks link vcds protseduurile: VCDS protseduur
"The caliper pistons do not move back into the caliper, this is normal." St kolb tuleb siiski mehaaniliselt tagasi suruda. Seda et läbi seisupiduri nö remondiasendisse viimise käigus ka pidurikolb tagasi tõmmatakse nii et saaks uued klotsid vahele panna ei ole üheski netimaterjalis välja toodud.
Eeltoodud linkides polnud mingeid keerulisi elektroonikavidinaid - tavaline akulaadija. Ja tavalised pidurikolvi tagasisurumise vahendid - ühel juhul täitsa tavaline pitskruvi. Loomulikult kui tehakse esimest korda asju siis tuleks selleks aega võtta ja võimalikud juhendid ja ka videod enne läbi lugeda ja vaadata. Aga pole mõtet antud teemast ka teha mingit kosmoseteadust.
teet82
Registreerunud 17.11.13
postitati 14.11.14 17:20 Tsiteeri
ElsaWin-is pole tõesti juttu akulaadijast, aga originaal tester hakkab ise niikuinii hädaldama, et aku laeb ennast teatud ampritega tühjaks ja käseb laadija taha panna. Pole ise aktiivne VAG-COM kasutaja ja ei tea, et kas see annab samamoodi häiret.
Aga kas VAG-COM-i ja akulaadija abil tõmbab siis kolvi ise sisse?
postitati 14.11.14 18:26 Tsiteeri
Algselt postitas: teet82
Kolb ei saa ise kuidagi sisse minna. Ehitus on lihtsalt selline. Ja laadija on vajalik kui aku on tühi. Kindluse mõttes tuleks laadija peale panna kuna mootorid võtavad suhtpalju voolu ja kui aku nõrk võib miski pooleli jääda või ei saavuta tagasilasets õiget pinksust. Kui on võimalik siis ikka laadija peale. Samas mehaanikud ei pane peagu kunagi laadijat peale ja pole miskit juhtunud.
postitati 15.11.14 04:45 Tsiteeri
Algselt postitas: automees6
Kui aku on uus ja hea, pole laadija vajalik. Samas teades, kui ruttu c6 süüde sees poolpiduse aku voolu maha tõmbab, võiks siiski ühendada. Olneb, kui osavnäpp mehaanik allpool toimetab. Ise olen tavaliselt üleval ja allun käsklustele, lahti,kinni,test.:D
Üle 10min. Aega ei kulu.
[PHP: 17.5% - SQL: 82.5%]
