Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Kas Audi 100C3 2,5tdi R5 88kw mootorile sobib uuema C4 diisli käigukast?
Pealkiri: Kas Audi 100C3 2,5tdi R5 88kw mootorile sobib uuema C4 diisli käigukast? (Vastuseid: 9 | Vaatamisi: 1122)
j2mis
Registreerunud 07.01.07
Auto: C5, B5, Zafira A
postitati 25.10.14 18:18 Tsiteeri
Võimalus saada vanaraua hinnaga normaalses korras, minimaalse roostega 1990a Audi 100C3 avant 2,5tdi R5 88kw.
Autol peal kliima ja 4 korda el aknad.
Probleem selles, et käigukast jooksis totaalselt hunnikusse, hammasrattad katki ja korpus ka katki.
Küsimus suurele ringile, et mis käigukast sobiks sinna veel otsa ? Ilmselt midagi C4 seeriast !?
Äkki sobib sinna mootori otsa mingi 2,5tdi 85kw 5 või 6 käiguline manuaalkast ?
Või teine variant, et äkki on kellegil antud masinale 5 käigulist kasti pakkuda
SalmA
Auto: 100 Sedan 2.5 TDI 90
postitati 26.10.14 07:15 Tsiteeri
ABP, AAT(kuni 1994/05) ja 3D omad sobivad kindlasti 1:1- le.
SalmA
villis21
Registreerunud 01.06.11
Auto: 100 tdi quattro 92a.
postitati 26.10.14 17:00 Tsiteeri
Mul oleks pakkuda AAT 6ne manuaal kast koos hoobadega.
bensiin on pintslite pesemiseks,
Diislis peitub jõud!
j2mis
postitati 26.10.14 18:05 Tsiteeri
Ei tea kas hoovastiku peab ringi ka tegema ? Pikemaks või lühemaks ? AAT kast istub ilma ringi tegemata selle vana 2,5tdi otsa ? Sidur, korv ja hooratas sobib vana ?
postitati 26.10.14 18:54 Tsiteeri
5k kasti asemel 6k kasti paigaldades on vaja terve käiguhoovastik ära vahetada.
j2mis
postitati 26.10.14 20:18 Tsiteeri
Ok. Aga hoovastiku pikkus ja värgid on samad kõik ? Krutin auto küljest lihtsalt vana hoovastiku lahti ja panen uue ? Reaalselt plekki ei pea lõikama hakkama ?
Kuidas on lood veovõllidega? Sobivad vanad või tuleb koos C4 kastiga uued veovõllid ka külge kruttida?
Ühesõnaga kui näiteks panengi C4 kasti, kas siis tuleb midagi ratsida ka või on tükkide olemasolul ainult Plug&Play ?
rkrimm
Registreerunud 09.06.08
Auto: V8 4.2TT man projekt; S6 2,2t man.
postitati 26.10.14 21:57 Tsiteeri
C3 kohta ei oska küll 100% väita kuid tean, et D11 (V8) mis on sisuliselt C3 on kuskil 1cm kitsama esisillaga. Et siis võimalusel vanu pooltelgi kasutada või miskit asemele leiutada.
j2mis
postitati 27.10.14 06:26 Tsiteeri
Niih, võimalik saada siit Hiiumaalt kohapealt Audi 100 C4 2,5tdi 1991a 5 käiguline manuaalkast.
Niipalju veel jutuks, et sigaril mille alla see kast läheb on juba 5 augulise poldivalemiga sild all. Ehk siis C4 alge või nagu eelpool nimetatud D11 ?
SalmA
postitati 27.10.14 06:42 Tsiteeri
Algselt postitas: j2mis
Lihtsalt 89 aasta lõpp läksid pea kõik rida 5 mootoriga sigarid üle 5 poldi valemile.
5-käiguline kast peaks küll 1:1 minema. Mainiks ära, et kastiks, mis peal on, omab tähist AUW
SalmA
ahtos
Registreerunud 18.09.07
postitati 27.10.14 16:55 Tsiteeri
Mul oli90a sigar millel olid küll 4ja auguga veljed all.
[PHP: 33.5% - SQL: 66.5%]
