Pealkiri: Veakoodidega hädas. 3,3tdi 2001a (Vastuseid: 1 | Vaatamisi: 1722)
paharett27
Registreerunud 02.01.14
postitati 14.10.14 19:53 Tsiteeri
Tere ei leidnud kohta kuhu veakoodidega kirjutada siis teen siia uue teema.
Kes oskab mulle need lahti seletada.
Siin tänase diagnostiga tulemused!
Address 01: Engine Labels: None
Part No: 4D0 907 409 A
Component: 3.3l/4VTEDC G400AG D04
Coding: 00016
Shop #: WSC 02313
VCID: 2649E841C2FC2C9
WAUZZZ4DZ1N007410 AUZ7Z0Y1575842
1 Fault Found:
17567 - Signals from MAF-1 and MAF-2
P1159 - 35-00 - Implausible Correlation
Readiness: N/A
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 08357
Shop #: WSC 02313
VCID: 31630B1DFB327B1
No fault code found.
Address 08: Auto HVAC Labels: 4D0-820-043-MYX.lbl
Part No: 4D0 820 043 Q
Component: A8-Klimavollautomat D13
Coding: 00083
Shop #: WSC 02313
VCID: 2A511C71D6E4089
1 Fault Found:
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to Plus - Intermittent
Address 11: Engine II Labels: None
Part No: 4D0 907 409 B
Component: 3.3l/4VTEDC 0000AG D03
Coding: 00016
Shop #: WSC 02313
VCID: 2757E545C5F6351
Address 15: Airbags Labels: 4D0-959-655-AI8.lbl
Part No: 4D0 959 655 T
Component: Airbag Front+Kopf 4000
Coding: 00417
Shop #: WSC 02335
VCID: 438F51D5518EF91
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 C
Component: Lenkradelektronik D00
Coding: 01001
Shop #: WSC 02313
VCID: 2C5D1A69DC10169
Address 17: Instruments Labels: 4D0-919-033-MYX.lbl
Part No: 4D0 919 033 CA
Component: D2-KOMBIINSTR. VDO D29
Coding: 00180
Shop #: WSC 02313
VCID: 65CBAF4DFF7AE71
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
Address 18: Aux. Heat Labels: None
Part No: 4D0 815 071 B
Component: Zuheizer Diesel D49ˆ
Coding: 00002
Shop #: WSC 02313
VCID: 2045FE59A0D8C29
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 G
Component: ZV-Pumpe, DWA, Funk D06
Coding: 13130
Shop #: WSC 02324
VCID: 3973333D2342B31
1 Fault Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
Address 37: Navigation Labels: 4B0-035-192-RNSD-37.lbl
Part No: 4D0 035 192 K
Component: RNS 4.1 H05 BNO 0011
Address 45: Inter. Monitor Labels: None
Part No: 4D0 951 177 B
Component: Innenraumueberw. D06
Coding: 00001
Shop #: WSC 00000
VCID: 2855E679C8E83A9
Address 55: Xenon Range Labels: 4B0-907-357-DYN.lbl
Part No: 4B0 907 357 C
Component: dynamische LWR D05
Coding: 00001
Shop #: WSC 00000
4 Faults Found:
01539 - Headlights Not Adjusted
35-00 - -
00774 - Level Control System Sensor; Left Rear (G76)
28-10 - Short to Plus - Intermittent
00776 - Level Control System Sensor; Left Front (G78)
31-00 - Open or Short to Ground
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 56: Radio Labels: 4B0-035-192-RNSD-56.lbl
Component: Radio BNO 0001
Coding: 00117
Shop #: WSC 02313
Address 57: TV Tuner Labels: 4D0-919-146.clb
Part No: 4D0 919 146 B
Component: TV Tuner H03 0504
Coding: 0000010
Shop #: WSC 00000 000 00000
VCID: 2855E67998E83A9
Address 65: Tire Pressure Labels: 4D0-907-273.lbl
Part No: 4D0 907 273 C
Component: Reifendruckueberw. D209
Coding: 22140
Shop #: WSC 02324
1 Fault Found:
01477 - System Switched Off
35-00 - -
Address 76: Park Assist Labels: 4D0-919-283.lbl
Part No: 4D0 919 283
Component: Parkingsystem A8 RDW D07
Coding: 01108
Shop #: WSC 00000
VCID: E8D5267988687A9
Address 77: Telephone Labels: None
Part No: 8E0 862 333
Component: Telefon Nokia3 0101
Coding: 0003125
Shop #: WSC 02313 785 00200
VCID: E6C92841D27C6C9
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4D0 927 156 DL
Component: AG5 01L 3.3lTDI RdW 0707
Coding: 00001
Shop #: WSC 02313
VCID: 76E9F80152DC1C9
End ---------------------------------------------------------------------
real-illusion
Registreerunud 27.09.11
Auto: A6 3.0 TDI 165 kw Q
postitati 14.10.14 19:57 Tsiteeri
Ei ole vaja alati oma teemat teha, selleks on olemas VAG-COM teema.
Selle leiad siit!
Üldiselt veakoodide kohta infot leiad siit!
Life is tough.
[PHP: 6.0% - SQL: 94.0%]
