Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 2.5tdi 132kw kõrgsurvepumba vahetus
Pealkiri: 2.5tdi 132kw kõrgsurvepumba vahetus (Vastuseid: 22 | Vaatamisi: 3516)
ivorturb12
Registreerunud 21.10.08
postitati 03.10.14 12:04 Tsiteeri
Kas 2.5 132kw tdi , 2002a audi a6, kõrgsurvepumba vahetuseks on vaja ka mõnda spets rakist? Või kui keeruline töö see on? Selge see, et kogu nina ja hammasirhm tuleb maha võtta, aga kui raske pumba enda vahetus on? Ja kui näiteks sooviks vaid pumba elektroonikat vahetada, et võtan teiselt pumbalt elektroonika, äkki see oleks mõtekam vms ??
raimo21
Registreerunud 21.08.09
Auto: A6
postitati 03.10.14 12:12 Tsiteeri
Hammasrihma pole vaja ära võtta.
ivorturb12
postitati 03.10.14 12:13 Tsiteeri
Pumba rihmaratta jaoks peaks olema ju.?
Ja kas on mingist rakist ka vaja? Küsin seda, sest BMW-l on pumba vahetuseks vaja rakist.
niffu
Registreerunud 04.11.04
Auto: C6, A6 & A6 Allroad ;Coupe Quattro Typ85 x 2
postitati 03.10.14 12:27 Tsiteeri
Algselt postitas: ivorturb12
Pumba vahetuseks ei pea nina maha võtma. Süüte paika panemiseks on kolme tööriista. Väntvõll, nukk (mõlemad pooled) ning pumba jaoks. Kõiki neid on võimalik soetada. Hammasrihma ei tule maha võtta. Ainult vasaku nukaratta pealt kõrgsurvepumbale minev lühike hammasrihm. See kas tahad pumpa või elektroonikat vahetada eriti töö käiku ei muuda. Lihtsam on elektroonikat vahetada kui pump juba maas on.
http://www.ebay.com/itm/VW-AUDI-SKODA-2-5-TDI-V6-ENGINE-CAMSHAFT-Timing-lock-tool-AFB-AKE-AKN-AYM-N09085-/281269471139?hash=item417c f787a3&item=281269471139&pt=Motors_Automotive_Tools&vxp=mtr tööriistad sellised + kõrgsurvepumba jaoks on pulka vaja millega pump ülemisse asendisse lukustada.
raidoaudics
Registreerunud 16.11.06
postitati 03.10.14 12:37 Tsiteeri
Keera pump null asendisse, pane kuuese puuriga pump lukku kõigepealt. Siis keera rihmapinguti lahti rihm maha, poldid, torud voolikud küljest ära ja ongi pump käes. Ei ole vaja seal nina lahti kakkuda, ega mingeid eraldi rakiseid, kolmveerand tundi tööd ja pump käes. Uus pump samamoodi kuuese puuriga lukku ja uuesti peale. Väga lihtne.
ivorturb12
postitati 03.10.14 13:02 Tsiteeri
Selge, tänud vastamast. Aga eraldi elektroonika vahetuse kohta küsiks veel. Korra uurisin, tundus et elektroonika osa eemaldamiseks tuleb vaid mõni tähikpeaga polt lahti keerata ja ongi pmslt kõik? Või sain valesti aru ?
raimo21
Auto: A6
postitati 03.10.14 13:32 Tsiteeri
http://www.youtube.com/watch?v=BUXHxXUdB3U
yks
Registreerunud 04.05.11
postitati 03.10.14 14:31 Tsiteeri
selline asi siis ka kui elektroonikat vahetad.
http://wiki.ross-tech.com/wiki/index.php/Immobilizer_III_Injection_Pump_Swapping
ivorturb12
postitati 03.10.14 14:55 Tsiteeri
Sain aru, et kui samakoodiga pumba pealt tuleb elektroonika, siis pole immoga probleeme ?
Raimole tänud, olin õieti aru saanud elektroonika vahetusest.
ferdinand
Registreerunud 17.01.03
Auto: 400,401,969
Kui on korras pump siis kindlasti on mõttekam kogu täiega ära vahetada.
ivorturb12
postitati 03.10.14 14:57 Tsiteeri
Aga olen muidu sellest immo asjast õieti aru saanud, et kui pump sama koodiga, siis immoga probleeme ei tule? Miks muidu elektroonikat eraldi ei soovita vahetada ?
raidoaudics
postitati 03.10.14 15:27 Tsiteeri
Ei tule sul mingit probleemi, kui on korras aju ja korras pump teeb omavahel tööd nagu pudin, pole vahet mis koodiga see aju või pump seal on .
audipoiss
Registreerunud 25.05.08
Auto: audi a4 b8
postitati 03.10.14 18:12 Tsiteeri
Uus pump tuleb autoga koostööd tegema õpetada küll, immo ei lase autol käima minna.
Autoklaaside kiletamine toonimine Tartus. +372 5322 5715 http://www.toonimine.eu/
Kohtusid kiviga? Nüüd on aeg meid külastada! http://www.tartuautoklaasid.ee/
Fugitive
Registreerunud 12.02.06
postitati 03.10.14 18:19 Tsiteeri
See immo asi sõltub pumbast ning auto väljalaske aastast, 2002a masin läheb ilmselt niisama uue pumbaga käima.
audipoiss
Auto: audi a4 b8
postitati 03.10.14 18:29 Tsiteeri
Minuoma nt ei läinud käima peale pumba vahetus.
ivorturb12
postitati 03.10.14 20:08 Tsiteeri
Panid sama koodiga pumba ?
yks
postitati 03.10.14 20:35 Tsiteeri
Asi on vist rohkem kinni selles kas autol on immo II või immo III
Kui kaabel olemas vaata
[Select]
[01 - Engine]
Look at the first "Extra" field. The first 17-digit string is the VIN. The second 14-digit string in the Immo-ID.
[Close Controller, Go Back - 06]
---OR---
[Select]
[01 - Engine]
[Meas. Blocks - 08]
Select Block 081.
[Go!]
The first 17-digit string is the VIN. The second 14-digit string in the Immo-ID..
[Done, Go Back]
Oleneb su asukohast, Ma liigun Keila Tallinn saan selle immo pini välja sul lugeda kui tahad.
Mis sul pumbaga on, et seda vahetad?
ivorturb12
postitati 04.10.14 07:20 Tsiteeri
Kahjuks ma üldse Põlvamaal. Aga pumba elektroonika otsas.
yks
postitati 04.10.14 08:22 Tsiteeri
Paljudel juhtudel on seal trans surnud ja neid vahetatakse
ivorturb12
postitati 04.10.14 08:26 Tsiteeri
Kevadel see trans juba suri ja vahetati ära. See toodi pumbast välja eraldi üldsegi. Kas neid transe kuskilt eraldi ka saadaval on ?
yks
postitati 04.10.14 08:54 Tsiteeri
jah, elektroonikapoest. See trans vajab jahutust ma arvan, rippus lihtsalt juhtme otsas?
ivorturb12
postitati 04.10.14 09:14 Tsiteeri
Algselt postitas: yks
Eip. Kütusefiltri ja pumba vahelise vooliku vahele oli pandud mingisugune vask torujupp ja sinna külge pandud trans- võimalik et joodetud sinna külge.
Kui see trans läbi, kas siis võimalik et mingi hetk läheb auto kuidagi käima ja siis jääb varsti seisma, või ei saa ta üldse käivituda kui see omadega otsas?
Pihustitorudest lõi autot kütet välja küll, kuid tõenäoliselt liiga nõrgalt
audipoiss
Auto: audi a4 b8
postitati 04.10.14 17:53 Tsiteeri
See trans maksab oomipoes 2euri
[PHP: 22.5% - SQL: 77.5%]
