Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890 Eesti Audi Klubi foorum - õlikulu
Kui lihtne on vahetada klapisääre tihendeid ja palju see maksab, muidugi huvitab veel see kus seda tehakse ?
Igasse urkasse ei lähe enam !
real-illusion
Registreerunud 27.09.11
Auto: A6 3.0 TDI 165 kw Q
postitati 19.09.14 10:48
Algselt postitas: riho.tamme
Saksamaal tehakse päris korralikult audi esinduses.
Life is tough.
riho.tamme
Registreerunud 12.04.07
Auto: Audi A8 D2 V6 2.8
postitati 19.09.14 11:33
tänan
tean seda ise ka, aga soovin mõnda arukamat vastust, sest hetkel Saksamaale pole asja
TaSa
Registreerunud 20.01.12
Auto: Audi 100 C4,Audi A4 b5
postitati 19.09.14 11:42
Kus kanti siis asja on?
real-illusion
postitati 19.09.14 13:25
Algselt postitas: TaSa
Kohvi paksu pealt loen, et asub krimmist 400 km eemal Mirgorod-is. Ühtlasi sõidab ka vaz-iga. Ei tea miks üldse siin foorumis on. Eriti, kui kirjutada
ka ei oska.
Life is tough.
joffe
Registreerunud 04.04.14
postitati 19.09.14 13:28
ka ei oska.
Ja-jah, paistab, et endalegi õigekirjavead võõrad pole.
[PHP: 23.3% - SQL: 76.7%]
