Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Autol metsik õlikulu.
Pealkiri: Autol metsik õlikulu. (Vastuseid: 19 | Vaatamisi: 2051)
dUBZ
Registreerunud 27.11.10
Auto: D2 4.2Q, C4 2.8Q, B6 4Motion, B5.5 TDI
postitati 08.09.14 18:20 Tsiteeri
Tere! Mure siis selline, et auto on viimase suvega hakanud ropult õli sööma, olen 3 kuuga ca 3-4 liitrit peale valanud ja kui rohkem peeneks anda, siis on kohe ka tagant sinine ving väljas, mis pikapeale küll taandub. Saan aru, et klapisääretihendid on raudselt enda aja ära elanud ja sooviksin nüüd teada, et kui neid vahetama hakkan, siis mis jupid peaksin veel ära vahetama selle töö käigus, et õlikulu normaalsuse piiridesse tagasi tuua. Aitäh!
dUBZ
jokerAudi
Registreerunud 09.02.08
Auto: Superb 2018
postitati 08.09.14 18:52 Tsiteeri
Kohvipaksult eeldan, et tegemist 2.6 V6 bensukaga?
TaSa
Registreerunud 20.01.12
Auto: Audi 100 C4,Audi A4 b5
postitati 08.09.14 19:01 Tsiteeri
Võimalik,et ka õlirõngad oma aja ära elanud.
dUBZ
postitati 08.09.14 19:31 Tsiteeri
Vabandust, autoks on jah profiilis olev 2.6 V6 bensukas. Õlirõngad ei tohiks veel aega ära elanud olla, sest õlirõhku hoiab veel vägagi ilusti.
postitati 09.09.14 05:33 Tsiteeri
Algselt postitas: dUBZ
Ülemine korrus korda ja ikka uued tihendid. Sääretihendid, juhtpuksid, sooveldus ja saab hea.
mtaudi
Registreerunud 26.02.07
postitati 09.09.14 05:36 Tsiteeri
Milleks sooveldus - hakka veel kaasi maha võtma - 99% juhtudest piisab sääretihendite vahetusest, mis ei ole kuigi kallis ega ka aeganõudev töö. Pole üldjuhul nendel juhtpuksidel viga midagi ja piisab kivistunud sääretihenditest, et taga helesinine pilveke järgi sõidaks. Läbi elatud traagika - 1000km = 1L õli ja kõik sai normidesse sääretihendite vahetusega.
postitati 09.09.14 05:41 Tsiteeri
Algselt postitas: mtaudi
Ei hakka vaidlema, igaühel oma nägemus asjast.
genekas
Registreerunud 30.01.03
Auto: järgmist plaanimas
postitati 09.09.14 18:43 Tsiteeri
Kui puksid on lobedad, on need uued tihendid päris varsti omadega õhtul ja endine olukord taastunud. Hullemal juhul tulevad tihendid "loperdavate" klappide peal pukside otsast lahti ja siis on seis veel hullem, kui enne vahetust.
Kui tihendite vahetamine plaanis, siis tasuks selle ajal üritada kontrollida, milline on klapisäärte lõtk seal pukside sees ja vastavalt sellele otsustada, kas pelgalt tihendite vahetus on piisav.
dUBZ
postitati 09.09.14 20:11 Tsiteeri
Nii, aitäh info eest :) Kahjuks see mootor on minu mõistusele juba natukene üle jõu ja samuti pole tööriistu millega seda tööd saaks teostada, seega küsiks parem, kas keegi oskab Pärnus mõnda head hinna-kvaliteedi suhtega kohta soovitada, kus saaks lasta selle töö ära teha? :)
dUBZ
postitati 09.09.14 21:23 Tsiteeri
Tugeval kiirendusel sinine suits on ikka enamasti õlirõnga viga. Klapisääre tihend teeb peale käivitust suitsu ja kerget vinet. Paarutamisega klapisääre suits ei muutu eriti.
pampkuri
Registreerunud 08.03.04
postitati 10.09.14 08:25 Tsiteeri
dUBZ
Trevocar Bussipargis Mere tn, viisin just hommikul oma diisli sinna kaane remonti. Mina olen Trevori juures käind 12 aastat.
mtaudi
postitati 10.09.14 11:48 Tsiteeri
Algselt postitas: automees6
Muutub ja kuidas veel. Vastupidest Sinu kirjutatule väljendus sääre tihendite rabedus just kiirendamisel tekkiva sinise pilve näol. Kohapeal ja peale käivitamist oli suht hea, kuniks lapatsid sai antud.
100
Aeg maha
Registreerunud 12.04.10
Auto: 100
postitati 10.09.14 11:54 Tsiteeri
Ehitajate tee ääres kus on Kaasiku kohvik (Autoasi ühel pool ja Foral ning Würth teisel pool), seal olen näinud mehi plokikaaned käes kusagile kõndimas, minu arust seal veidi enne Kaasiku ust paremal on mingi koht, aga nime ei tea.
dUBZ
postitati 10.09.14 16:09 Tsiteeri
Aitäh kohtade soovituste eest :) Suitsemise koha pealt veel niipalju, et kui kohapeal käia, siis pole midagi viga, nagu normaalne auto, ainult tagant tulev toss on natukene selline kibe, pole nagu puhas, kui uued katid jne all olid. Suitsemine väljendub eelkõige jah, kas siis kui minna anda või maanteel üle 3000 pöörde sõites. Kui niiöelda inimesi moodi sõita ja iga käiguga üle 2500 ei lähe, siis on kõik timmis. Õlirõngaste koha pealt ma olen kuulnud, et siis pidi õlisurve ka hakkama ära kaduma kui rõngad otsas, aga sellel autol on surve minuarust väga OK, külmamootoriga on 5bari nagu ikka olema peaks ja soojast peast pole kunagi näinud, et alla 2 oleks läinud(130 kraadi õlitempi juures on surve kusagil 2.1-2.2 bari).
Siim89
Registreerunud 07.06.10
Auto: C5 1.8T; C4 2.2TQ;
postitati 10.09.14 16:20 Tsiteeri
Algselt postitas: 100
Ehimet pidi tegema jah igasugu toredaid asju metalliga.
S4 OMC 238 km/h, ET 13,04
Maaryo
Registreerunud 15.11.09
postitati 10.09.14 16:48 Tsiteeri
Minu teadmiste kohaselt õlirõngad küll kuidagi õlisurvet ei mõjuta!
Õlirõnga eesmärk on siiski selles, et õli ei satuks põlemiskambrisse.
QUATTRO
Auto: 5,2 Cherokee 4x4
postitati 11.09.14 07:22 Tsiteeri
Selle jutu põhjal kontrolliks esimese asjana karterituulutuse üle. Ehk siis klapikambrikaantes olevad "filtrid" ja drosselklapi otsas asetseva plastkopsiku.
postitati 11.09.14 16:09 Tsiteeri
Õlirõnga kulumine ei mõjuta kuidagi õlisurvet.
Monka
Registreerunud 03.04.13
Auto: c5 avant
postitati 11.09.14 16:41 Tsiteeri
Kui õlirõngad läbi tossab pidevalt. Lihtne ju
Teostan veakoodide lugemist ja kustutamist,
Tel.58257569
roy
Registreerunud 02.09.05
postitati 13.09.14 08:41 Tsiteeri
Tuulutus puhtaks ja klapisääretihendid. Sai ka endal vahetatud. Küll teine mootor aga õli läks kõvasti ja nüüd on ka tõukurid hommikul vait.
Pidevalt ongi vastused sellised, vaheta, lihvi ja värvi üle kõik mis annab teha, kahjuks ei käi kõik soovitaja rahakoti arvel:D
[PHP: 20.4% - SQL: 79.6%]
