Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - audi 2,5 tdi 103kw pumba reguleerimine
Pealkiri: audi 2,5 tdi 103kw pumba reguleerimine (Vastuseid: 12 | Vaatamisi: 2095)
samy12310
Registreerunud 15.12.13
Auto: Audi A6 C4 2,5tdi 103kw
postitati 29.06.14 16:39 Tsiteeri
Oleks siis selline küsimus et, kas keegi oskab öelda et kes ja kus teostatakse pumba stendi. Kardan et natuke paigast väljas.
teet82
Registreerunud 17.11.13
postitati 29.06.14 18:27 Tsiteeri
Mida sa täpsemalt teha tahad? Pump maha auto pealt ja mingisse stendi, või auto peal pritsehetke ja kütusekoguse reguleerimine arvuti abil?
uaintfckme
Registreerunud 22.09.10
Auto: AEL Q
postitati 30.06.14 07:25 Tsiteeri
Oleks hea, kui kirjeldaks kuidas auto käitub. Mis probleemid autol on, et kahtlustad pumpa valet reguleeringut. Üldjuhul seda reguleerimist tehakse ikka siis, kui pump auto peal. Stendis saad vb ainult pumpa korrasolekut kontrollida. Seadistamine ikka käib siis kui pump autol peal, ja arvuti sabas.
Milleks vedada mittevedavaid rattaid kaasas!? :)
samy12310
postitati 01.07.14 08:14 Tsiteeri
Tahaks lihtsalt juhtmed taha lüüa ja kontrollida kuna peale pumba rihma vahetust hakkas musta viskama
uaintfckme
Auto: AEL Q
postitati 01.07.14 08:28 Tsiteeri
Kas käivitus muutus ka paremaks/halvemaks? Kuidas mootorihääl muutus? Rihmavahetusel saab ainult süüdet muuta. Sellega seoses ei tohiks rohkem väga tahmama hakata. Siis kui pumbakaant liigutada, siis saab küttekogust muuta, ja sellega seoses muutub ka tahmamine.
samy12310
postitati 01.07.14 18:41 Tsiteeri
Käivitub samamoodi mootor töötab samahästi, aga kui süütenurk on natukene varasem/hilisem siis kütuse põletamine ka ju halvem ja hakkab tahmama. Minek ka natuke halvemaks muutunud. Tahakski kellegi asjatundja juurde viia kes viskaks juhtmed taha ja vaataks milles asi on et kas on pumpa vaja natuke timmida või peab viga kuskilt mujalt otsima.
teet82
postitati 02.07.14 20:54 Tsiteeri
Tegelikult võib ju muutuda ka nukkvõlli asend, juhul kui ei tehta õigesti seda rihmavahetust ja ei kasutata ettenähtud rakiseid ja töövõtteid. Kui Võru kaugel pole siis saan aidata arvutiga.
tel. ...
samy12310
postitati 05.07.14 10:18 Tsiteeri
nii nüüd sai aruitaga ära käidud ja teada saadud et süüde oli 10kraadi varajasem, sai siis lastud õigeks panna aga kütet saab endiselt palju peale oleks vaja kedagi kes on ja oskab pumba pead timmida
uaintfckme
Auto: AEL Q
postitati 05.07.14 11:12 Tsiteeri
Algselt postitas: teet82
tel. 51919778
Sel mootoril ei kannata mootoririhma valesti väga panna. Kohe on klapp(id) peas. Kui õigesti mäletan, siis uhele poole üks hammas, ja teisele poole pool hammast on mängimismaad.
teet82
postitati 05.07.14 19:20 Tsiteeri
Pidasin silmas seda kui ei fikseerita nukkvõlli tagumisest otsast nagu ette nähtud. Selliseid mootoreid ei toodeta enam ammu, millel lihtsalt võetakse vana rihm maha ja pannakse uus asemele, loomulikult võib olla erandeid. Reegilina puudub nukkvõlli rihmarattal kiil, rihmaratas lüüakse lahti koonuse pealt, nukkvõll lukku vastava rakisega, rihm peale ja pingule, ning seejärel nukkvõlli rihmaratta polt kinni. Kui kaasaegsel mootoril on keegi ise märke joonistanud markeriga nukkvõlli rihmarattale, siis ilmselgelt pole asi korrektselt tehud! Kes räägib hammastest ühele või teisele poole, siis uurigu kuidas rihma vahetatakse sellel mootoril.
Sellel konkreetsel autol oli pritsekogus umbes 2.0mg peal, mida on ilmselgelt liiga palju. Ei hakanud seda näppima, sest polnud varuks uut pumbakaane tihendit. Minu kogemused on, et mõnikord hakkab vana tihend lekkima pumbakaane liigutamisel.
uaintfckme
Auto: AEL Q
postitati 06.07.14 09:34 Tsiteeri
2.0 on tõesti liiga palju. See ka viimane piir suht mida panna. Üle selle( ehk väiksem number) hakkab üldjuhul juba puterdama. Normaalne oleks see jätta ikkagi 3,5 ja 4,5 vahele. Oleneb muidugi mootori seisukorrast. Kõige õigem oleks muidugi küttekoguseid muuta arvutiga. Aga sellise töö eest kusitakse tavaliselt palju raha. Mul veel pole pumbakaane tihend lekkima hakanud mehaanilise liigutamise peale. Ja pumba osa toimetab korralikult.
postitati 06.07.14 15:07 Tsiteeri
Kindlasti pole õige kütusekogust muuta arvutiga.
Ikkagi pumbast mehaaniliselt paika võimalikult täpselt (ajust adaptsioon 128 peale) ning ainult viimased 0.5mg arvutiga.
See kehtib juhul, kui keegi tarkpea on pumba kaant liigutanud. Kui seda pole liigutatud, siis ei ole vaja ka näppida, tehasest on täpselt paika pandud.
samy12310
postitati 06.07.14 15:54 Tsiteeri
seda ma ei oska öelda kas keegi on pumba pead näppind v ei, aga oleks super kui keegi kes oskaks paneneks küttekoguse õigeks :P
[PHP: 23.1% - SQL: 76.9%]
