Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi A4 B5 ´99 oil sensor
Pealkiri: Audi A4 B5 ´99 oil sensor (Vastuseid: 7 | Vaatamisi: 994)
zxcv123
Registreerunud 12.06.14
Auto: Audi A4 B5 1.8
postitati 12.06.14 00:27 Tsiteeri
Helloo.
Ühesõnaga, peale auto käivitamist lööb armatuurile märgise "oil sensor" (kollane)
Milles asi võib olla?
yanekk
postitati 12.06.14 04:13 Tsiteeri
Algselt postitas: zxcv123
Helloo.
Õli vähe, andur vigane, juhtmete halb ühendus.
Best ET 12.08 :)
zxcv123
postitati 12.06.14 21:48 Tsiteeri
Õli olen kontrollinud, kõik OK.
Aga pole eriline spets. Seega, kust selle anduri leida võib? Või pistiku?
Peale kapoti lahti tegemist tühistab vea*
HK89
Registreerunud 30.06.10
Auto: A4 Avant 3.0 TDI Q
postitati 12.06.14 22:46 Tsiteeri
Vaata karteri alla, juhipool küljes. Tegemist on vaat et tüüpveaga. :) Kapott naljakal kombel mõjutab seda, jah. Kui peaksid uut varuosa vajama, siis ole valmis, et B-osaga sama tramburai jätkub. Mul üks sõber tegi hiljuti selle läbi. :D
zxcv123
postitati 13.06.14 14:18 Tsiteeri
Aga asi võib ka pistikus olla?
Ühesõnaga palju õnne mulle :D Avastamisrõõmu jätkub ;)
zxcv123
postitati 13.06.14 14:31 Tsiteeri
A ja kust selle pistiku leida võib? Vaataks ennem selle üle, äkki asi hoopis seal. :D
yanekk
postitati 13.06.14 14:39 Tsiteeri
Äkki hoopis süveneks asja ja teeks ühtteist omale selgeks, piisavalt juba vihjeid olnud.
Kui sa pole pistikut leidnud, siis ei ole sa ka seda andurit ise veel näinud ja anduri asukoht suht selgelt kirjas juba.
Best ET 12.08 :)
HK89
postitati 13.06.14 17:24 Tsiteeri
On üpris loogiline, et pistik on seal, kus on ka andur...
[PHP: 23.5% - SQL: 76.5%]
