Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi A4 1.6 pöörded kõiguvad
Pealkiri: Audi A4 1.6 pöörded kõiguvad (Vastuseid: 1 | Vaatamisi: 1056)
Mbknitro17
Registreerunud 06.01.13
postitati 12.05.14 19:26 Tsiteeri
Tere, mure selline autol pöörded kõiguvad ja ennem ei lõpeta kui hoo täiesti maha pidurdad. Hakkasin asja uurima ja sai siis esimesena segusiiber puhastatud ja lambda vahetatud kõikumine kadus, aga samal õhtul võtsin aku ööseks maha ja kui hommikul peale tagasi kõikusid jälle, aga tekkis ka selline probleem juurde, et auto ei liigu enam nii nagu ennem vaid jõnksutab ja jõud ka kadunud see toimub siukse vahelduva eduga. Segusiiber sai ka ära kalibreeritud. Diagnost näitas veel halli andurit. Aga peale seda aku maha võtmist kadus jõud ( vahelduva eduga) ja pöörded ei lõpeta ennem kõikumist kui hoo maha pidurdad. Oskab keegi aidata, milles asi ?
varemax
Registreerunud 27.03.11
Auto: Audi a4 b8 2,0 tdi 2008
postitati 13.05.14 04:23 Tsiteeri
Lisaõhk mis on lugematta?. Kui kindel,et segusiiber on õiges seades ?
[PHP: 21.8% - SQL: 78.2%]
