Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Jagaja
Pealkiri: Jagaja (Vastuseid: 4 | Vaatamisi: 791)
Adrs
Registreerunud 26.04.14
postitati 26.04.14 17:48 Tsiteeri
Jagaja
Tere
Auto- Audi 80, 2.0, 85 kw, ABK
Kas on normaalne, et jagaja rootorit käega keerates liigub ka võll kaasa natuke?
arsi
Registreerunud 09.02.06
postitati 26.04.14 18:03 Tsiteeri
Ma lugesin vähemalt 10 korda ja ikkagi ei saanud sittagi aru .
Adrs
postitati 26.04.14 18:09 Tsiteeri
No kas jagaja rootor peab seisma ilusti paigal, nii, et jagaja võll ka ei liigu, või võib see seal liikuda natuke edasi-tagasi?
Maaryo
Registreerunud 15.11.09
postitati 26.04.14 18:11 Tsiteeri
Arvestades kuidas jagajat ringi aetakse, siis ilmselt mingi imeväike lõtk on lubatud. Vana auto värk :)
Adrs
postitati 26.04.14 18:55 Tsiteeri
Ja vähe suurem loks ajab juba süüte valeks?
[PHP: 16.2% - SQL: 83.8%]
