Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Probleemne tühikäigulüliti reostaat Audi A8 (D2) 4.2
Pealkiri: Probleemne tühikäigulüliti reostaat Audi A8 (D2) 4.2 (Vastuseid: 2 | Vaatamisi: 1280)
Henxen
Registreerunud 13.07.09
Auto: Audi A8 (D2) 4.2 V8
postitati 24.04.14 06:21 Tsiteeri
Probleem on selles, et auto ei käivitu või läheb käima alles viienda korraga. Soojaandurid ja bensiinipump on vahetatud aga ikka sama jama. Panin autole juhtme taha ja arvuti näitab et viga on tühikäigulüliti reostaadis. Kus see reostaat täpsemalt asub ja milline see välja näeb ?
aixx
Registreerunud 21.03.05
postitati 24.04.14 08:20 Tsiteeri
Vaata mootori tagaotsast sisselaske juurest. Pilti ei õnnestu sealtmootorit maha võtmata teha.
http://thumbs1.ebaystatic.com/d/l225/m/mlrqTBfgQVXj321aeEz56ig.jpg
http://www.callparts.de/sites/default/files/productimages/BIR11000167962030/951565_0.jpg
Henxen
postitati 24.04.14 13:08 Tsiteeri
Tänud :)
[PHP: 28.7% - SQL: 71.3%]
