Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Gjensidige kindlustuse koostööpartnerid
Pealkiri: Gjensidige kindlustuse koostööpartnerid (Vastuseid: 9 | Vaatamisi: 3658)
Lauri0112
Registreerunud 20.03.12
Auto: A5 S-line 3.0tdi
postitati 16.04.14 06:20 Tsiteeri
Tere,
Ei osanud mujale postitada.
Küsimus lihtne, milline töökoda on gjensidige kindlustuse valikust parim.
Nimekirja leiab SIIT.
Oli plekimõlkimine, esitiival tsingi kiht ka nähtavasti kannatada saanud. :(
Tänud ette ära. :)
Joel
Registreerunud 01.10.02
postitati 16.04.14 12:07 Tsiteeri
Mina olen Ammeco Autos käinud mitu korda ja ei kurda. Kui midagi ei meeldi tuleb otse öelda ja tehakse ringi, vastu ei hakata.
ralf
Registreerunud 08.12.07
Auto: A6c6q,2*c4tdi,b4,a5,SQ5
postitati 16.04.14 13:02 Tsiteeri
Ammeco autosse ei soovita minna.Töö alla igasugust arvestust.Arve peal kajastatud jupid olid vahetamata.Kaks korda sai lastud tööd ümber teha ja ikka on sitasti.Aasta hiljem kapott roostetab,nii et otsustage ise.
RistoN
Registreerunud 25.10.10
postitati 16.04.14 13:41 Tsiteeri
Pool aastat käisin tagasi esitiiva värvimisel Bacanias ning jäi küll väga hea tulemus. Roostest pole ka veel ühtegi märki.
Samuti käisin umbes pool aastat tagasi Värvaltransis tagastanget värvimas ja seal pole samuti midagi nuriseda.
Mõlemas kohas väga hea teenindus
postitati 16.04.14 19:05 Tsiteeri
Sa võid ükskõik kust töökojas pakkumise võtta. See nimekiri seal on kohtadest, kes nendega koostööd teevad ja saavad kahjujuhtumit registreerida, see ei tähenda, et sa just sinna pead minema.
Lihtsalt infoks.
real-illusion
Registreerunud 27.09.11
Auto: A6 3.0 TDI 165 kw Q
postitati 16.04.14 19:10 Tsiteeri
Algselt postitas: prj
Lihtsalt infoks.
Ma tegin kindlustusele oma poolse pakkumise, lisaks nende poolt valitud töökojale. Oli odavam ja kanti raha 3 päeva jooksul üle. :) Kasumisse jäin ca 400€-ga.
Life is tough.
postitati 16.04.14 19:16 Tsiteeri
Mu valik jäi pidama Autokliiniku peal, eks tulemustest saab mõne nädala pärast rääkida.
Lauri0112
postitati 22.04.14 19:24 Tsiteeri
Sai seekord valitud Hitech. Puhtalt sellepäras, et jäi täpselt koduteele. Siiamaani on õnneks kõik sujuvalt läinud ja järgmine nädal läheb auto töösse.
Siis saan ka oma kogemused Gjensidige kindlustuse ja Hitech tööga kirja panna.
1.5 nädalat sai uue autoga kulgeda, kuni õhtul auto juurde minnes tore üllatus ees ootas.
Järgmine päev sain õnneks tänu kaameratele süüdlase leitud.
http://www.upload.ee/image/4016942/1.jpg
priidik
Registreerunud 17.04.03
postitati 24.04.14 22:22 Tsiteeri
Lihtsalt infoks.
Varsti jõustub uus liikluskindlustuse seadus, mille ühe olulise muudatusena on kindlustusettevõttel kohustus sõiduk taastada, rahalist hüvitamist lubatakse ainult erandjuhtudel. Teisisõnu jõuame lähemale olukorrale, kus väga raske on pöörduda mujale kui kindlustusseltsi koostööpartneri poole. Lihtsalt infoks.
Lauri0112
postitati 03.05.14 10:26 Tsiteeri
Nonii, 3 nädalat juhtumist umbes möödas ja nüüd auto jälle ilus ja korras.
Siinkohal suured kiidusõnad Hitech töölistele. Töö tundub väga korralik, lootetavasti ka rooste kimbutama ei hakka, aga eks seda ole aasta pärast näha.
Sammuti Gjensidige kindlustuses sujus kõik kiirelt ja korralikult. Olen lugenud jubedaid jutte sellest seltsist, aga minu kogemused olid seekord positiivsed.
Üritan lähipäevil pildi ka tiivast üles panna. :)
[PHP: 43.5% - SQL: 56.5%]
