Pealkiri: Käigukast avarii-re˛iimis / tip-tronicu probleem (Vastuseid: 6 | Vaatamisi: 3207)
Kobrukas
Registreerunud 01.12.13
postitati 15.04.14 12:46 Tsiteeri
Hey,
Copyn oma inglise keelse algse postituse mille panin ka rahvusvahelistesse Audi foorumitesse...Ei hakka seda ümber tõlkima, kuna see on piisavalt lihtsas inglise keeles niikuinii.
Loodetavasti see on okei :)
I have not managed to find a solution for D3 series A8 yet. I have a 4.2 2003 A8.
My gearbox has been running in emergency mode since the time I bought it. (see picture below). Nothing on the dash changes, as i go through different gears. It doesn't change to numbers either, as i switch to tip-tronic.
http://2imgs.com/2i/t/7a32f2d80b.jpg
I thought it was due to tiptronic not working. Nothing happens as I push + or -, nor if i put the shifter into tip-tronic mode in the first place. I scanned quite a few forums, and the most common issue for the tiptronic not working was that the magnet under the circuitboard around the shifter had fallen away.
Since I sent the center console into repairshop for 1 of the buttons to be fixed, it was a good chance for me to look at the magnet.
http://2imgs.com/2i/t/2f67a78d5e.jpg
It actually is totally different from the tiptronic magnets i've seen on pictures so far. Usually it's a square-shaped one, and goes on top of the small metal square part which I also have in my picture. My magnet is cilinder shaped and you can see it laying on it's side there. It does not fit under the circuitboard on top of the square metal part.
If i switch between D,R,N,S or P, the letters or the led lights next to the shifter light up. As i put the shifter into tiptronic, the car drives just as it was in D and non of the lights are brighter than the other ones.
As the shifter is in D, D lights up
http://2imgs.com/2i/t/d0985872a1.jpg
In tip-tronic mode, none of the lights are brighter.
http://2imgs.com/2i/t/a7ef2f05d6.jpg
Now I am not sure if the magnet of a 2003 A8 should be where it is in my picture and that way?
Secondly, does tip-tronic even work if the gearbox is running in emergency mode?
And if you have any ideas for fixes, feel free to let me know. Any help would be greatly appriciated.
tarts
Registreerunud 25.09.02
postitati 15.04.14 15:35 Tsiteeri
Kui kast avariis, siis ei tööta see ka tiptronicus.
www.eksperthooldus.ee
Kaits
Registreerunud 01.03.03
Kasutaja on foorumis
Auto: RS 6 Avant
postitati 15.04.14 19:58 Tsiteeri
Käigukasti küljes olev andur/lüliti F125 võib ka palju lollusi põhjustada. Kast läheb avariisse, sest kasti aju ei saa aru, millises asendis valits reaalselt on.
Vahetamise jutt siin:
http://www.audipages.com/Tech_Articles/auto_transmission/f125switchreplace.html
Veakoode annab mingisuguseid?
Kobrukas
postitati 15.04.14 22:14 Tsiteeri
Lasen ära skännida, siis oskan täpsemalt veakoodid välja tuua.
Kobrukas
postitati 21.04.14 12:17 Tsiteeri
02 - Auto Trans alt selline error siis:
Tiptronic Switch (F189) : Implausible signal : P17153
Peale errori kustutamist ei ole kast enam avariire˛iimis kuni lülitan D peale, (ei pea isegi tiptronicusse lükkama) ja kast tagasi avariire˛iimis.
On ideid?
tl470487
aeg maha
Registreerunud 06.07.11
postitati 21.04.14 12:46 Tsiteeri
Ideed on siin:
http://wiki.ross-tech.com/wiki/index.php/18161/P1753
Kobrukas
postitati 21.04.14 14:55 Tsiteeri
Jätkuvalt tundub see magneti asi kõige loogilisem. Otsisin ka VW kaste ja see silindrikujuline magnet ikka ei tohiks seal lahtiselt tilbendada nagu mulle tundub...see peaks olema kuskil mujal...aga kus...täpselt ei tea.
Paar sarnasemat pilti :
http://forums.vwvortex.com/showthread.php?6022296-Fix-for-Fault-(F189)-Tiptronic-Switch-Implausible-Signal
http://bigskyeuro.com/images/gallery/mikewire/a4/tip_shifter/8.jpg
Täpselt samasugust magnetisüsteemi pole veel näinud nagu mu kastil.
[PHP: 8.3% - SQL: 91.7%]
