Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Sobiv väntvõlliasendi andur Audi A6 avant 2000a 1.9 TDI 81 kW mootorile!?
Pealkiri: Sobiv väntvõlliasendi andur Audi A6 avant 2000a 1.9 TDI 81 kW mootorile!? (Vastuseid: 0 | Vaatamisi: 625)
vildekeemik
Registreerunud 11.04.13
Auto: Audi A6 Avant 1.9 TDI 81kw
postitati 14.04.14 14:14 Tsiteeri
Tere,
küsimus Teile spetsialistid ja asjahuvilised.
Kas antud autole Audi A6 avant 1.9 TDI 81 kW 2000 a. , mootori koodiga AVG, sobib ka väntvõllipöörete andur mis tehniliste andmete järgi sobib AFN mootori tüübile!??
Samas on ka väntvõlliasendi andurid, mis peaks sobima AFF mootorile aga sobivus muude markidega info alt leiab AFF sobivuse ka AVG koodiga mootoritega?
Ette tänades!
Timo
[PHP: 23.8% - SQL: 76.2%]
