Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Kloppiv hääl taguosas
Pealkiri: Kloppiv hääl taguosas (Vastuseid: 4 | Vaatamisi: 931)
Diplomat
Registreerunud 31.08.12
Auto: Audi A6 Quattro, 132kw 2.5l
postitati 14.03.14 14:39 Tsiteeri
Hei!
Selline huvitav problem siin.. et just hakkas autol paremal pool tagaosas miski kloppima.. see juhtub nii sirgel sõites, kui ka kurvides.
Väga kõva kloppimine ei ole, aga kuulda on kenasti.
Katsusin rattaid, et ehk ratas on lahti vms.. aga ei tundunud olevat.
Oskab ehk keegi öelda, mis teha võiks või mis võiks valesti olla
mtaudi
Registreerunud 26.02.07
postitati 14.03.14 14:41 Tsiteeri
Vaata piduriklotsid ka üle, kas ikka püsivad omal kohal jne.
Diplomat
postitati 14.03.14 14:42 Tsiteeri
See on küll mõistlik. Iseenesest on piduriklotsid vahetatud umbes aasta tagasi.. aga näppinud neid ei ole veel. Eks ma vaata. Aitäh
AronL
Registreerunud 07.09.08
Auto: M140i xDrive
postitati 14.03.14 15:16 Tsiteeri
Algselt postitas: Diplomat
Esimese asjana võiks vastavasse asutusse minna, kus tehakse kindlaks mis autol täpsemalt viga on. Läbi interneti keegi ühtegi kindlat diagnoosi panna ei oska sellisele asjale.
Järjest võimalike asjade vahetamine võib lõppkokkuvõttes veel kulukamaks minna.
Diplomat
postitati 14.03.14 17:49 Tsiteeri
Parem esimene ratas oli täiesti suvalt nii lahti, et kerge pööramise peale tulid mutrid lahti.. päris rumal lugu.
Loodan esmaspäeval veermiku kontrolli saada, sest midagi tundub ikka vale..
[PHP: 25.3% - SQL: 74.7%]
