Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 1.9tdi Surve mootoris?
Pealkiri: 1.9tdi Surve mootoris? (Vastuseid: 17 | Vaatamisi: 1922)
piip
Registreerunud 10.01.14
postitati 04.03.14 18:42 Tsiteeri
Avastasin et sõites oli õlirada taha tekkinud. Kui kapoti avasin nägin et kõik oli õli täis.
Õlikork oli puruks läinud, mingi toru laiali lennand ja ühest torust mis turboga ühendatud(turboõlitus?) purskab õli.
Mootor ise töötab muidu korralikult ei mingit klõbisemist, kolksumist vms.
Mida kontrollida?
http://www.upload.ee/image/3923476/145350.png
kuno666
Registreerunud 15.07.06
Auto: 2xV8 & 1x 2,2 20v.
postitati 04.03.14 19:28 Tsiteeri
See ju turbo õlitus toru ja kui see katki siis sealt lendabgi õli.
piip
postitati 04.03.14 19:31 Tsiteeri
Võtsin toru lahti, toru oli terve. Võimalik et umbes?
Sparkle
Registreerunud 27.12.07
postitati 04.03.14 19:35 Tsiteeri
Algselt postitas: piip
võtsin toru lahti, toru oli terve. Võimalik et umbes?
Et kui umbe läks lõi toru pildabsteks? Võimatu.
kuno666
postitati 04.03.14 19:36 Tsiteeri
Võimalik ,et mingi ummistus aga kus kohast ta siis õli välja viskab ?
quattrodiisel
Registreerunud 04.07.13
Auto: A4 B7 TDI Quattro
postitati 04.03.14 19:39 Tsiteeri
Võib olla juhus, et toruotsast koonus katki.
piip
postitati 04.03.14 19:40 Tsiteeri
Panen homme video aga viskab välja turboõlitustorust, mootori poole pealt. Nähtavaid vigastusi ei ole.Kui mootor välja suretada siis mingi 2 min. susiseb ja pritsib.
Sparkle
postitati 04.03.14 19:42 Tsiteeri
Panen homme video aga viskab välja turboõlitustorust, mootori poole pealt. nähtavaid vigastusi ei ole. kui mootor välja suretada siis mingi 2 min. susiseb ja pritsib.
Sellele pole mõelnud, et turbo nüüdsest õlituseta ja vurab sul kuivalt ringi?
piip
postitati 04.03.14 19:45 Tsiteeri
Olen kyll, aga hetkel seisab.Ja keegi ei sõida. Kogu õli on mootorist kadunud. Video kannatab teha.
madjs
Registreerunud 28.10.02
Auto: Audi 80 b4 1,9tdi, Suzuki VX 800, Golf 2 GTI, Megan Coupe 108kw
postitati 04.03.14 19:50 Tsiteeri
olen kyll , aga hetkel seisab. ja keegi ei sõida. kogu õli on mootorist kadunud. Video kannatab teha.
No otsi se viga enne järgmist käivitust üles, muidu tõesti lased midagi kokku seal, esimesena lendavad kepsusaaled ja turbo kui õlisurve puudub. Ja kui ikka hirmus tahtmine purskavast õlist video teha siis kalla vähemalt õli mootorisse.
piip
postitati 04.03.14 19:53 Tsiteeri
Seda kindlasti ,et juurde valada XD
Sparkle
postitati 04.03.14 19:57 Tsiteeri
Ära siis kallist õli sisse pane, puhas resurssi raiskamine. :D
piip
postitati 04.03.14 19:58 Tsiteeri
Mingit mis võtta on, peaasi et päris kuiv poleks.
madjs
postitati 04.03.14 20:03 Tsiteeri
mingit mis võtta on, peaasi et päris kuiv poleks.
Vaata suured ja väiksed algustähed üle, enne kui moded sulle kallale tulevad. Aga jh. huumorit võid teha aga ära motot kanni keera kui juba seal suuremaid kahjustusi pole.
piip
postitati 05.03.14 18:59 Tsiteeri
On kellegil pakkuda turboõlitus toru? Audi 80 1.9tdi avant 66kw 1993a. PS.
kuno666
postitati 05.03.14 19:01 Tsiteeri
Kõige lihtsam on minna hüdroskandi ja see lasta seal teha .
piip
postitati 05.03.14 19:11 Tsiteeri
poes eriti kirved hinnad? eitea pole uurind.
frames
Registreerunud 20.09.04
postitati 05.03.14 20:11 Tsiteeri
Omalgi juhtus paar aastat tagasi see toru otse õlifiltri juurest pooleks minema.
Uurisin ka poehindasi ja täpselt ei mäleta, aga lihtsa toru kohta oli hind ikka
väga kirves. Lasin siis Hydroscandis uue teha. Otsad on metallist, aga vahepealne
osa õli kõrgsurve voolik. Siiani peab vastu. :)
[PHP: 22.3% - SQL: 77.7%]
