Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi q7 2008 õhkvedrustuse probleem
Pealkiri: Audi q7 2008 õhkvedrustuse probleem (Vastuseid: 1 | Vaatamisi: 1506)
intsu879
Registreerunud 22.02.14
Auto: Audi S8 D2 4,2 250kw
postitati 22.02.14 15:27 Tsiteeri
Tere.Mure siis selline,et auto tagumine ots ei taha reageerida kui siis ainult mingi sentimeeter variantide lift ja offroad vahel.Esiots ok, tagumine parem padi nagu ei laseks õhku ei sisse ega välja,offroad ja lift asendis liigub see sentimeeter üles alla.Arvuti viga ei näita,sõites mingilt maalt hakkab kollane vea tuli vilkuma ja annab vastuseks,et auto kõrguste vahed ratastel ei ole õiged kuna see üks ratas ei toimeta .Kui valida offroad siis linnakiirusel ok kuigi natuke jäik kuidagi ja tuli põlema ei hakka .Nüüd valida aga comfort ja automatic siis tahab autot madalamaks lasta ja kohe ka viga.Oskab keegi siin nõu anda kust otsast viga otsida?Tänud ette Indrek :)
intsu879
postitati 22.02.14 16:41 Tsiteeri
See loodiandur oli mul läbi paremal esimesel rattal just ja vahetasin ära ja sellega ei tohiks probleeme olla.Jama on,et arvuti ka midagi ei näita.Vaatasime padja rõhud üle ,kui langetada siis esimesed laseb tühjaks aga tagant parem ei liigu ja vasak nagu tahaks tulla aga jääb ka kuskiltmaalt kinni.See võibolla sellepärast,et see teine ei taha tulla.Väike mõte oli,et mingid klapid niisuksega jamavad.Kui nüüd jälle tõsta liftiga kõige üles pole probleem ja hakkab tõstma kompressor töötab .Alla see offroadist enam ei tule.
[PHP: 20.8% - SQL: 79.2%]
