Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi A6, C5, 2.5TDI (starteri)probleem käivitumisega
Pealkiri: Audi A6, C5, 2.5TDI (starteri)probleem käivitumisega (Vastuseid: 7 | Vaatamisi: 2157)
raino84
Registreerunud 29.12.05
Auto: Audi A6 Allroad 2,7Tdi, 140kw, 09
postitati 21.02.14 09:37 Tsiteeri
Lühidalt öeldes, ei võta starterit alati järgi - lihtsalt vaikus. Ei plõgista, ei viska üle, vaid lihtsalt tumm.
Ca 1,5a tagasi ilmutas probleem esimest korda. Tol hetkel kuna ka aku oli vana jne sai see asi aku süüks pandud. (ka tüübid Gilmontis olid samal arvamusel) Uus aku peal ja kõik tore, kuni ca paari kuu pärast oli sama teema jälle tagasi - ei käivitu alati. Sai uuritud siit - sealt (kuna alati see mittekäivitumine ei avaldunud, siis oli ka suht keeruline viga tuvastada) kuni siis sai vaadatud uus (kasutatud, korralik) starter ja Flamekos see vahetatud.
Nägu jälle naeru täis, ca 6-kuud muretut sõitu kuni nüüd paar nädalat tagasi JÄLLE sama pull, viimane täna hommikul. Ja mida ma siis olen tähele pannud on see, et aitab kui pidurit all hoides käigukangiga tõmmata P->R->D edasi tagasi või liigutada autot ja siis uuesti P peale lükata - käivitub. Ma saan aru, et see tundub imelik lugeda, aga nii on :)
Kas tõesti võib olla jälle starter läbi? On äkki multitronicul mingi misiganes andur, mis segast paneb? Vag-com´iga nagu mingeid vigu ei jäta.
Mingid mõtted oleks väga teretulnud. Kohe ei tahaks jälle nina eest lasta laiali kiskuda ja starterit vahetama hakata.
mtaudi
Registreerunud 26.02.07
postitati 21.02.14 09:58 Tsiteeri
Lõhnab selle järele, et käigukasti/käigukangi mingi andur on läbi või anna ühendust. Kui aju ei tea, kas kang on P asendis, siis ei anna starterile voolu peale. Peale natuke jeblamist saab andur aru ja annab signaali, et nüüd on OK ja laseb auto käima panna.
raino84
postitati 24.02.14 13:23 Tsiteeri
Algselt postitas: mtaudi
Täna jälle sama teema. Aitas jälle auto asendi muutmine ja siis väikse kõigutamisega N pealt P peale.
Igatpidi tekib tunne, et vool ei jõua nendel hetkedel starterini.
On kellegil veel mõtteid?
Martin89
Registreerunud 02.10.07
postitati 24.02.14 17:15 Tsiteeri
Vaata arvutiga mis käik siis on kui starterit taha ei võta. Muidugi võib starteri relee ka vigane olla. Aga see ei ole seotud käigukangi liigutamisega.
postitati 24.02.14 17:29 Tsiteeri
Algselt postitas: raino84
C6 olen P asendi lülitit vahetanud ja sai ok. Auto ei näe, et kang on parkingu peal ja ei lase käivitada. Arvutiga saab neid asju ilusti kontrllida. Vastav viga peaks ka sees olema.
raino84
postitati 24.02.14 20:30 Tsiteeri
Algselt postitas: automees6
Üritan nüüd järgmine hetk, kui käima ei lähe, vag-com´i järgi saada ja vaadata. Küll aga näidikutes PRNDS tuled kangi liigutades vahetuvad. Veakoode varasemast tuvastanud pole.
raino84
postitati 25.02.14 20:40 Tsiteeri
Suutsin siis jälle tabada hetke, kui ei käivitunud. Mingeid veakoode "Engine" ja "Auto trans" all polnud. Või peaks kusagilt mujalt otsima?
Auto transi measure blocksi alt tegin mõned pildid. "Lever position", "Gear selected" jne muutuvad vastavalt käiguvalitsa liigutamisele.
Mida/kust ma veel vaadata võiks? Hetkel nagu tundus, et see käivitumine/mittekäivitumine juhtus kuidagi täiesti suvaliselt:S Krdi raske on seda kirjeldada. Aga siiski mulle tundub, et mingi seos on auto asendi muutumisega.
http://www.upload.ee/image/3910213/2.JPG
http://www.upload.ee/image/3910232/3.JPG
raino84
postitati 28.02.14 08:32 Tsiteeri
Kuhu peale Revali ja Flameko veel Tallinnas minna võiks? Või on äkki keegi klubilistest nõus hetke vaatama seda anomaaliat?
[PHP: 25.7% - SQL: 74.3%]
