Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Mootori ja käigukasti vaheline ölileke. Lahendatud.
Pealkiri: Mootori ja käigukasti vaheline ölileke. Lahendatud. (Vastuseid: 41 | Vaatamisi: 4088)
marko416
Registreerunud 19.07.13
Auto: Audi a4 b7 1.9 tdi
postitati 16.02.14 14:59 Tsiteeri
Avastasin,et peale hoorata ja siduri vahetust hakkas kàigukasti ja mootori vahelt ôli jooksma.Vàntvôlli simmer sai ka vahetatud.Láksid tagasi motohoovi autoremondi tôôkotta,
Ôeldi,et simmer vôis praak olla.Ega mina eriti ei usu seda,see on tàitsa jama mis nad ráágivad.Simmeri vahetuse aeg olin ise kohal ja nàgin,et nad panid sinna hermeetikut.
Isiklikult járeldan seda,et simmer oli halvasti paigaldatud ja hermeetik jààb samuti kùsimàrgi alla.
Nôudsin nendelt,et garantii korras teeks korda.Vastuseks sain,et tasuta me ei tee midagi kui siis vàikse soodukaga,kuna simmer on praak.
Kahjuks enam ei julge sinna autod viia.
Olen nùùd aja broneerinud MT autohooldusesse,hakkavad tööd ümber tegema.Loodan vàga,et MT tehakse korralik tôô.
Mis te arvate sellest loost?Kas tegin ôige otsuse?
Kui ohtlik on sellises olukorras autoga sôita?
meli666
Registreerunud 30.09.08
Auto: Audi A4-B5 1,9 81 kw
postitati 16.02.14 17:09 Tsiteeri
Kas muidu sina ise ostsid varuosad või olid need nende poolt? Viimasel juhul ei peaks sina kohe kindlasti mitte uuesti asja kinni maksma. Kui oli praak, siis on see varuosa müüja ja töökoja vaheline asi. Tehku ekspertiis ja lahendagu omavahel, et kas oligi tootja praak või paigaldusviga.
Kui aga sinu poolt toodud varuosad, siis midagi nõuda kahtlane. Võidakse väita, et oled halvasti hoidnud, toonud vale varuosa jne.
Isiklikult ka küll simmeri praaki ei usu. Pigem on valesti paigaldatud. Kas siis viltu sisse löödud või vasaraga hoopis loppi pekstud.
Välistada ei saa ka vale simmeri paigaldust. Osad on niiöelda pöörlemissuunatundlikud. Ehk siis simmeri sees olev võll peab pöörlema õiget pidi. Kas sellel sinu Audil ka selline simmer kasutuses, seda öelda ei oska.
Kui ikka nende poolt olid osad, siis tasub Tarbijakaitsesse või ka telesse pöörduda.
yanekk
postitati 16.02.14 17:20 Tsiteeri
Algselt postitas: marko416
Kuradi hästi elatakse, et kliendile saab nii öelda.
Endal eelmisel aastal oli neli korda, kus varuosa defektne.
Loomulikult selgub see siis, kui masin juba koos.
Võib olla see väikse Haapsalu eelis aga ilma suurema probleemita maksis varuosa tarnija kinni nii uue varuosa, kui ka uue töö.
Best ET 12.08 :)
real-illusion
Registreerunud 27.09.11
Auto: A6 3.0 TDI 165 kw Q
postitati 16.02.14 17:52 Tsiteeri
Ühtlasi võiks kirjutada ka koha nime, kus õeldi. Usun, et tean, aga ei hakka niisama mustama. :)
Life is tough.
marko416
postitati 16.02.14 18:20 Tsiteeri
Motohoov oü
yanekk
postitati 16.02.14 18:23 Tsiteeri
Motohoov oü
Mitte paha pärast aga ehk põhjendad, mis lased autot remontida meesel, kes tavaoludes tegelevad kaherattalistega.
Best ET 12.08 :)
marko416
postitati 16.02.14 18:24 Tsiteeri
Algselt postitas: meli666
Varuosad olid minupoolt.simmeri ostsin vanavaruosa jàrgi.Dorpani simmer oli.
Kusimus on selles kas simmerile pannakse tihendus hermeetikumi?
Siim89
Registreerunud 07.06.10
Auto: C5 1.8T; C4 2.2TQ;
postitati 16.02.14 18:26 Tsiteeri
Mina küll ei tea, et pannakse hermeetikut. Teiseks, milleks selline osa üldse suht tundmatu varuosa panna? Elring, Victor Reinz või originaal. Hinnad ei ole kallid - töö aga on.
Kui nüüd MT tulebki välja, et on praak varuosa - räägi maaletoojaga ja las tootja maksab kinni kogu jama.
Kui on praak töö - peaks pöörduma tarbijakaitsesse ning siis asja edasi ajama töökojaga kahju korvamiseks.
E: Ma arvan et Dorpani all mõtled siiski Toprani, mis on pehmelt öeldes ostes juba rämps ja sellisesse sõlme kindlasti ei soovitaks. Mingi suva õlivarda võid neilt osta, aga see on ka kõik.
S4 OMC 238 km/h, ET 13,04
Ma usun, et kindlasti ei panda. Pigem tehakse uus simmerling/röngastihend enne kohale asetamist kergelt õliga niiskeks, et paigaldamist kergendada.
MT-st tasuks nüüd võtta/küsida akt, et kinnitaksid, et tegu oli kas praak vöi valesti paigaldatud detailiga, selle alusel on ehk lihtsam edasist asjaajamist liigutada.
marko416
postitati 16.02.14 18:27 Tsiteeri
Algselt postitas: yanekk
Motohoov oü
Tegeletakse seal autoremondiga.
http://www.motohoov.ee/index.php?option=com_content&view=category&layout=blog&id=52&Itemid=106
marko416
postitati 16.02.14 18:33 Tsiteeri
Seda ma teen kohe kindlasti.
Tänud abi eest!
marko416
postitati 16.02.14 18:34 Tsiteeri
Algselt postitas: Siim89
Vabandust!Topran oli tôesti.
marko416
postitati 16.02.14 18:37 Tsiteeri
Mis see MT autoremont kujutab endast?Tehakse ikka viisakalt?
postitati 16.02.14 18:41 Tsiteeri
Mis see MT autoremont kujutab endast? Tehakse ikka viisakalt?
Väga kiidetud koht.
Siim89
postitati 16.02.14 19:20 Tsiteeri
Endalgi seal simmerit vahetatud ja jäi kenasti pidama. Ka kõik muud asjad, mida ise teha ei kannata/viitsi lähevad sinna. :)
marko416
postitati 16.02.14 20:20 Tsiteeri
Nii,et vôib usalda MT autohooldust
postitati 16.02.14 20:21 Tsiteeri
Kindlasti.
postitati 16.02.14 20:28 Tsiteeri
Varuosa oli seal sinu poolt, vabalt võis praak olla (miks üldse osta odavat asja, kui vahetus nii kallis on??), miks peaks motohoov asja tasuta korda tegema? Oleks, et nemad tõid jupi ja panid, aga nemad osutasid vaid paigaldusteenust. Ka varuosade garantiiga on mulle alati öeldud varuosa poes, et saad uue varuosa, kui vigasus tõestatud, aga remonti keegi kinni ei maksa. Mina ei näe Motohoovil hetkel otsest süüd. MT Autohoolduses käin isegi ja soovitan, samas sõber on aastaid juba seal motohoovis klient olnud ja ei ole probleeme olnud, juba ammu teevad ka "neljarattalisi". Aga kui sinna MT Autohooldusesse Toprani tihendiga lähed, siis nad vast hoiatavad sind, mis ohud sellise asjaga on.
postitati 16.02.14 20:42 Tsiteeri
Algselt postitas: audi_a4_v6
Varuosa oli seal sinu poolt, vabalt võis praak olla (miks üldse osta odavat asja, kui vahetus nii kallis on??), miks peaks motohoov asja tasuta korda tegema? Oleks, et nemad tõid jupi ja panid, aga nemad osutasid vaid paigaldusteenust. Ka varuosade garantiiga on mulle alati öeldud varuosa poes, et saad uue varuosa, kui vigasus tõestatud, aga remonti keegi kinni ei maksa. Mina ei näe Motohoovil hetkel otsest süüd. MT Autohoolduses käin isegi ja soovitan. Aga kui sinna Toprani tihendiga lähed, siis nad vast hoiatavad sind, mis ohud sellise asjaga on.
Njh, mõnes mõttes on Sinul õigus.
Samas aga kergelt vöiks "süüdistada" tegu, et lisati hermeetikut, vedas, et niigi läks, et lihtsalt tilkuma jäi, vedanuks hermeetiku tükki kuhugi mootori elutähtsasse osakonda, olnuks jama kui palju, vöi mis?
Ega me täpsemaid tagamaid ei tea, kuid põhimõtteliselt vöiks nõustuda 15-50% ulatuses oleva summa tasumist omaltpoolt.
Paljudel remondifirmadel vist on "siseeeskirjades" vms ka oma kindel seisukoht, kus nende poolt mitte soetatud/tarnitud vms detaili paigaldamisel vastutust ei vöeta, mis ka minu arvates on ka öige tegevus.
Loodetavasti ikkagi kogu saaga saab õnneliku ja mõlemale osapoolele rahulikult lõppeva lõpu.
postitati 16.02.14 20:57 Tsiteeri
Milleks ajada jama kui ei tea midagi. Seal peaks suur simmer koos väntvõlli asendianduriga olema mis tihendatakse ploki külge hermeetikuga. Mis mootriga ültse tegu on?
postitati 16.02.14 21:01 Tsiteeri
Algselt postitas: automees6
A4 b7 1.9 tdi 2007
postitati 16.02.14 21:16 Tsiteeri
http://www.myturbodiesel.com/wiki/rear-main-oil-seal-engine-speed-sensor-replacement-on-a-mk5-vw-and-audi/
Mismoodi selle ilma hermeetikuta pidama peaks saama?
marko416
postitati 16.02.14 21:39 Tsiteeri
Sai garaažis kàidud ja vaadatud vana simmerit(audi originaal simmer)seal ei olnud mitte mingisugust hermeetikut.Jarelikult pole hermeetikut sinna ettenàhtud.
postitati 16.02.14 21:44 Tsiteeri
Ok, kuid niipalju kui arusain (kui sain), siis hermeetikust polnud nagu juttu, mainitakse ära, et libestada ei lubata ja enne õliga täitmist peaks niisama paar tundi seisma ning peale öli lisamist veel oma 4 tundi, enne käivitust.
Sry, kui sain valesti aru.
E: ainus hermeetiku aka silikoon kasutus on mainitud ölivanni/panni installeerimisel.
15. Clean up the old oil pan sealing surfaces on the pan and block thoroughly and use a good quality silicone sealant (Permatex Great Stuff works well) and reinstall using 10mm socket and long handled 5mm ball head hex key. Torque to 15Nm (11 ft-lbs).
Ära ole nii resoluutne, vormista oma lause ümber nii: kas on võimalik, et hermeetikut pole sinna siiski ettenähtud? Pärast on niimoodi vähem oma sõnu süüa:cool:
[PHP: 31.9% - SQL: 68.1%]
