Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 2.5 tdi 132kw A6 / DTC 00575-Control Limit Not Reached
Pealkiri: 2.5 tdi 132kw A6 / DTC 00575-Control Limit Not Reached (Vastuseid: 7 | Vaatamisi: 3100)
TennoL
Registreerunud 23.01.14
Auto: A6 2.5TDI 132kw Quattro
postitati 16.02.14 14:31 Tsiteeri
Tere, olen teie foorumis täitsa uus : )!
Lugesin küll kõiki eelnevaid postitusi antud teemal kuid ikka olen hädas. Kuna nägin, et siin palju abivalmis inimesi soovisin oma teemas kõik täpselt välja tuua.
Nimelt soetasin endale
A6, 132kw 2.5tdi . 2002a Quattro
Kohe algul oli selline lugu, et jõud kadus ära ning pidurid jäid peale ( põlema hakkasid ABS ja ESP tuli armatuuris) seejärel enam pidurid peale ei jäänud kui piduriõli sai vahetatud kuid minek kadus täiesti ära.
Kohapeal gaasi andes läheb pöördesse ( vahel mitte) ning sõita üle 50-60 km/h gaas põhjas ei õnnestu, lihtsalt ei võta turbot järgi. Üsna harva, näiteks 10 km jooksul 1-2 korda võtab turbo järgi ja kõik normaalne kuid see ainult hetkeks nii, siis jälle vanaviisi -gaas põhjas kuid ei liigu edasi.
VCDS veakoodiks on 00575 - control limit not reached. See ka ainus kood. Tegin 011-st vcds -s ka logi, kui kellelgi huvi on võin seda jagada.
2 nädalat tagasi käisin vahetamas kõiki rihmasid, veepumba, termostaadi ning sidurikomplekti, mineku probleem oli juba siis kuid töökojas midagi eriti tarka selle kohta öelda ei osatud - ainult seda, et arvuti ei näita suurt midagi.
Kas vaakumvõimendi ning see piduriprobleem ning mineku kadumine võivad omavahel seotud olla?
Kas selliste nähtude puhul võib turbo omadega õhtal olla?
Veel parem ,kui teaksite soovitada kedagi, kes mulle vea tuvastamisel abi oskaks anda. Ise spetsialist sellel alal ei ole ja ka töökojas öeldi, et nemad ei oska öelda milles asi.
Abi otsin Raplamaal ( võimalikud ka Harjumaa ning Pärnumaa ).
Tänan teid juba ette, kes mind lahendusele lähemale aidata soovivad:)
postitati 16.02.14 14:59 Tsiteeri
Esiteks vaheta välja kõik peenikesed vaakumvoolikud.
Ei maksa suurt midagi ja võib juba ühe asja välistada. Need narmendavad kõigil peaaegu, mida näinud olen.
TennoL
postitati 16.02.14 15:25 Tsiteeri
Tänan, kindlasti tegelen sellega lähiajal.
Kas keegi sellest VCDS -s 011 kohta tehtud logifailist mis graafikuna vc scopes kuvatakse oskab midagi asjaliku välja lugeda?
Õnneks on olemas ka teine auto millega igapäevaselt tööl käia, ei julge Audit väga piinata sellises seisundis. Tahaks probleemile ikka lahenduse leida ja korda teha, mitte uusi probleeme juurde tekitada.
yanekk
postitati 16.02.14 17:30 Tsiteeri
Kas käigukast, mootor, kellablokk, ABS suhtlevad omavahel normaalselt.
Hetkel näppida suht sama murega samasugune automaat kastiga masin.
Seni tuvastatud vead, tänu kunagisele lisaimmo paigaldusele paneb kogu süsteem mingil hetkel pillid kotti + ABS aju on küpse.
Best ET 12.08 :)
meelo
Registreerunud 07.01.06
postitati 16.02.14 20:59 Tsiteeri
Uuri ka siit.
TennoL
postitati 17.02.14 07:16 Tsiteeri
Algselt postitas: yanekk
Käigukasti, mootori ja muu sellisega tundub kõik ok olevat, süüde oli vale kuid rihmasid vahetades pandi see õigeks -varem läks kehvasti tööle, nüüd kohe esimesest pöördest.
Ainuke kahtlane asi on ABS, sest piduritega ju oli algul jama ja praegu pidurid nagu eriti ei võtaks. Algul jäid pidurid harva peale , paar korda pikal sõidul, siis aga tihedamini, siis lugesin, et proovida ABS pistik välja võtta ja tundus nagu pärast seda hakkaski autot avarii reziimi lööma samas pistikut tagasi pannes ei muutunud midagi.
TennoL
postitati 21.02.14 08:38 Tsiteeri
Vahepeal vahetatud õhulugeja + õhufilter ja kontrollitud turbo.
Õhulugeja vahetusega kaasnes küll veidi parem minek, et nüüd võimalik kätte saada isegi 90 kiirus ja 100 kui pedaal täitsa põhjas pole..
Aga seda õiget jõudu pole ikka veel. turbo oli korras.
Oli tekkinud ka kaks uut veakoodi, mis õhulugeja vahetusega kadusid ja rohkem tagasi ei tulnud.
Proovin map andurit vahetada nüüd, sest see 00575 ju otseselt ka sellele viitab, mapi saan kätte homme.
Homme siis jagan veel infot, et kuidas see mapi vahetus mõjus.
Kui need asjad ei tööta siis mul ka järgmiseks neljapäevaks teise töökotta kontrolliks aeg lepitud, loodetavasti ei ole selle jõu kadumise lahendus enam mägede taga.
Annan siia infot seni kuni asi lahenduse leiab, võibolla tulevikus kellelgi kasu.
postitati 21.02.14 08:40 Tsiteeri
Rõhulekketest on vaja teha ning geomeetria üle vaadata, mitte veakoodide põhiselt andureid vahetada, millel tegelikult midagi viga ei ole. Ehk siis pädevat diagnostikat on vaja - soovitan soojalt, hoiad raha kokku.
[PHP: 21.5% - SQL: 78.5%]
