Pealkiri: audi c5 tagastange eemaldamine (Vastuseid: 4 | Vaatamisi: 1506)
Monka
Registreerunud 03.04.13
Auto: c5 avant
postitati 18.01.14 17:48 Tsiteeri
Mis moodi see tagumine stange ära käib c5 avandil?
KKaaleste
Registreerunud 06.10.10
postitati 18.01.14 18:46 Tsiteeri
Tagumisest ma ei tea. Aga äkki enamvähem samamoodi nagu esimene? Logard eest ja seal taga mutikad. Keegi oskab sulle täpsemalt öelda :D
Monka
Auto: c5 avant
postitati 18.01.14 19:01 Tsiteeri
Algselt postitas: KKaaleste
Esimese võib kinni silmi maha võta juba... Aga tagumine hetkel must maa
raul55
Registreerunud 09.12.09
Auto: Audi
postitati 18.01.14 21:23 Tsiteeri
Ehk on abiks:
http://www.upload.ee/image/3833867/C5_tagastange.png
1 - Combi bolt - 23 Nm
2 - Impact absorber
q Removing and installing → Chapter
3 - Cross member
q Remove cover.
q Unscrew combi bolt → Item and pull cross member out of longitudinal members.
4 - Centre support piece
5 - Right support piece
6 - Torx bolt - 1.5 Nm
q Used for attachment of left, right and centre support pieces
7 - Rear cross panel trim
q Unscrew oval head self-tapping screws → Item (6x).
8 - Oval head self-tapping screw - 1.5 Nm
9 - Support piece
q Replace when installing new bumper cover
q Do not release until bumper cover has been completely fitted → Fig.
10 - Cover
q Removing:
– Partially remove luggage compartment trim.
– Unscrew hexagon collared nuts → Item and → Item (accessible from luggage compartment).
– Disengage cover sideways from guide and detach.
– Unplug connectors if applicable.
q Support piece → Item need not be replaced if the same cover is re-used.
q Attaching cover to side panel → Chapter
11 - Guide
12 - Oval head self-tapping screw - 1 Nm
13 - Wheel housing liner
14 - Hexagon collared nut - 6 Nm
q 2x
15 - Hexagon collared nut - 6 Nm
q 2x
16 - Left support piece
17 - Seal
Monka
Auto: c5 avant
postitati 19.01.14 07:44 Tsiteeri
suured tänud
[PHP: 10.0% - SQL: 90.0%]
