Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi A6 rool ei lähe päris otseks tagasi peale kurvi
Pealkiri: Audi A6 rool ei lähe päris otseks tagasi peale kurvi (Vastuseid: 11 | Vaatamisi: 1819)
kristiaudi
Registreerunud 10.01.14
postitati 10.01.14 20:47 Tsiteeri
Tere, Olen päris värske Audi A6 2006a omanik. Kohapeal käib auto rool väga kergelt aga sõites mööda sirget teed ja kui tuleb selline väiksem kurv siis rool ei lähe ise otseks tagasi (eelmisa autoga läks ikka täitsa otseks ja oli kuidagi kergem sõites u 70-90km tunnis)). Olen proovinud ka nii et kui sõidan sirgel teel ja siis keeran rooli natuke viltu ja kui lahti lasen siis ta päris otseks küll ei tõmba vaid jääbki kraavi poole sõitma. Milles võib olla probleem?
postitati 11.01.14 06:04 Tsiteeri
Sillastendi kõigepealt. Järeljooks on see, mis rattad otseks tõmbab. Nagu poekärulgi.
kristiaudi
postitati 11.01.14 12:46 Tsiteeri
Sillastend on tehtud ja kõik oli korras
real-illusion
Registreerunud 27.09.11
Auto: A6 3.0 TDI 165 kw Q
postitati 11.01.14 13:04 Tsiteeri
Kas auto avariiline ja halvasti taastatud? Kere kõver pakuks selle peale, kui sillad korras. Või mis rehvid sul seal on? Tasakaalutus tehtud?
Life is tough.
postitati 11.01.14 13:09 Tsiteeri
Alles hiljuti siin foorumis keegi kaebas, et autol üks esiratas 10mm tagapool, sellel samuti ei tõmmanud rooli otseks peale pööramist. Hetkel ei leidnud seda teemat üles.
real-illusion
postitati 11.01.14 13:22 Tsiteeri
Mõtled vist seda, aga teksti on vist mudetud...
Life is tough.
postitati 11.01.14 13:33 Tsiteeri
Just seda jah, mingil põhjusel on osa tekstist kaduma läinud...
alts20
Registreerunud 28.09.05
Auto: Audi A6
postitati 12.01.14 10:12 Tsiteeri
Kuna selle kerega autol on esisillahoovad üsna kallid veel siis on võimalik, et endine omanik on kasutanud taastatud õõtsi. Taastatud õõtsad on aga uuena palju tihedamad kui originaalid ja sellest tulenevalt on esimesed ca 20 tuhat km rool üsna raske ja otseks ise päris kindlasti rool ei lähe peale kurvi, just nii nagu teema algataja kirjeldas.
Kui on nii siis see mure ajapikku kaob
jussbar
Registreerunud 10.01.12
Auto: C6 Allroad
postitati 12.01.14 12:07 Tsiteeri
Algselt postitas: alts20
Natuke vaidlen vastu endal ka taastatud õõtsad ja sellist probleemi pole olnud.
Võibolla see ei sobi siis foorumisse aga kunagi oli probleem ühe mersuga ,et rool ei läinud enam otseks ja aitas aind roolilati vahetus mis oli kosmilise hinnaga:(
alts20
Auto: Audi A6
postitati 13.01.14 21:25 Tsiteeri
Taastajaid on erinevaid. Kokku olen vahetanud 8-9 taastatud silda. Üks neist C6 ja ülejäänud C5 ja passat B5 ja B5,5. Teema algataja laadne probleem oli peale vahetust eranditult kõigil
kristiaudi
postitati 14.01.14 05:02 Tsiteeri
Eriti annab tunda siis kui paremale keerata ja peale seda ei taha rool tagasi tõmmata.
real-illusion
postitati 14.01.14 05:43 Tsiteeri
Algselt postitas: kristiaudi
Kus linnas sa asud? Kas oled käinud ka mõnes töökojas näitamas?
Life is tough.
[PHP: 27.2% - SQL: 72.8%]
