Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi 200 2.1T Säde kadunud
Pealkiri: Audi 200 2.1T Säde kadunud (Vastuseid: 7 | Vaatamisi: 1271)
haliseja001
Registreerunud 02.01.10
Auto: Audi 100 86a 2.2T 10V, Audi a6 c4 95.a 2.5AEl quattro
postitati 04.01.14 16:45 Tsiteeri
Tere.
Mure siis selline, et peale mootori vahetamist sädet ei ole.
Auto seisis ilma mootorita peaaegu kaks aastat kui ma seda alles ehitama hakkasin.
Süütepooli jõuab vool, ehk süütepooli peal olevatesse otsadesse kui ka pistikutesse, kuid süütepoolist jagajasse ei jõua.
Kuigi jagajasse tuleb küll süüte sisse keeramisel vool, kuid kontroll lamp põleb hästi tuhmilt.
Sai proovitud teist töökorras olevat süütepoole. Küünal väljas ja sai proovitud, et kas säde on. Korraks oli ja siis enam ei ole.
Kas see on reaale, et süütepoolid kukuvad lampi ära või halliandur?
Või on hoopis ajus asi?
Ette tänades, Sander! :)
postitati 04.01.14 19:42 Tsiteeri
Vaata kaitsmekarp üle. Kas need, kus on üks suur punane latakas peal, kirjaga Motor, on korras. Edasi vaata, et kõikide kaitsmepesade juhtmed oleks korralikult ühendatud.
Siis vaata rihmamärgid kõik üle. Hooratta pealt samamoodi. Veendu, et jagaja oleks 100% märgis. Võta sõber appi süüdet keerama. Ise keera enne jagaja kinnituspolt veidi lahti. Käivitamisel keera veidi edasi tagasi. Kui käima läheb on ajastus vale lihtsalt.
Aga seda viimast saad teha alles siis kui oled 110% kindel, et nii kõik mootori ajastuse märgid on paigas. Sh. ka jagaja rootor.
aixx
Registreerunud 21.03.05
postitati 05.01.14 09:50 Tsiteeri
Kogemus ütleb, et kommutaator või halli andur on läbi. Jagajasse tuleb süütepoolist ainult kõrgepinge, see mida sa mõõtsid on halli andurisse minev 5volti( mõnede arvates KG mootoril 12V) mis tuleb ajust. Üldiselt kui need töötavad, siis pole rihma asendil vahet, säde tuleb ikka, lihtsalt valel ajal.
EDIT : võib-olla see on ka abiks http://www.isham-research.co.uk/quattro/wiring/Audi200/mc03.gif
haliseja001
postitati 05.01.14 21:37 Tsiteeri
No ma homme lähen kruvin oma sõitvalt audi 100 2.2t süütepooli maha ja proovin seda peale. Kui ei, siis peab juba midagi muud olema viga.
Kui siis ka sädet ei tule, siis peab olema aju juba vigane!
Taavi.M(Audi&VW)
Registreerunud 20.05.10
Auto: Audi 200 treser megasquirt2 quattro, Passat 1.9tdi b5.5 4motion
postitati 06.01.14 05:34 Tsiteeri
Mul oli sarnane teema, ei olnud sädet ja ka pump ei löönud, viga oli hallianduri pistikus mis ei andnud ühendust.
haliseja001
postitati 08.01.14 17:14 Tsiteeri
Sain siis lõppudelõpuks vea ka teada!
Võtsin siis oma audi 100 pealt jagaja maha, Installisin audi 200 peale ja säde olemas! :)
Tänud abistajatele!
aixx
postitati 08.01.14 17:56 Tsiteeri
Ehk siis halli andur või selle pistikuühendus, kui keegi aru ei saanud.
haliseja001
postitati 08.01.14 19:10 Tsiteeri
Halli andur pigem!! ühendused olid laitmatult head! :D
[PHP: 22.1% - SQL: 77.9%]
