Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 2.3 b4 paugub ja käivitub külmalt halvasti
Pealkiri: 2.3 b4 paugub ja käivitub külmalt halvasti (Vastuseid: 3 | Vaatamisi: 1643)
Gennadi
Registreerunud 15.05.12
postitati 04.01.14 14:27 Tsiteeri
Tervist, mure nimelt selles, et Audi b4 2.3 ei taha korralikult käivituda. Suvel sellist probleemi ei ilmnenud, nüüd sügise lõpus pärast 3 päevast seismist käivitades alguses paugub nii summutisse, kui ka õhuvõttu. Mitu korda proovides siis lõpuks pärast suuremat pauku käivitub. Liikuma hakates alla 2000 pöörde poob mootori kinni ning kui juhtub välja surema, siis vajab uuesti mitu korda käiamist. Kui mootor soe, siis töötab ilusti ning kui ka ainult ühe päeva seisnud, siis käivitub ilusti.
Enne seda on ka selline probleem olnud, et pöörded hakkavad kõikuma 1100 ja 1200 vahel, aga see ilmselt sellest, et nn kilpkonnlõdviku vahel väike pragu ning võtab lisaõhku. Eriti hakkab kõikuma, kui sõita linnas viienda käiguga. Korra auto seisma jätta ja uuesti käivitada, ning enam ei kõigu. Kuum liim ja hermeetik seda pragu pole ära parandanud, nüüd proovin eriti tugeva kummiliimiga.
2.3 mootor on kahjuks võõras mulle, ehk keegi oskab juhendada, kust mida kontrollida.
Madisx
Registreerunud 06.09.08
Auto: Audi 100 c4 2,8 30v ja a4 facelift 2,8 Quattro
postitati 05.01.14 08:19 Tsiteeri
Õhu lõdvikut sa kestma ei saa ilma seda välja vahetamata!
Kontrolli autol: Temp andur, lambda näit töösooja mootoriga,
Õhulekked, pihustid kontrollida (pihusti pesad pole tavaliselt õhu tihedad), Kütuse süsteemi rõhk kontrollida, Juhtrõhk, Õhukaal puhtaks ja paika, Kütuse filter jne. kui kõik tehtud ja paigas, siis peab käima.
Madis.
Gennadi
postitati 19.01.14 12:10 Tsiteeri
Suured tänud vastuse eest, eile oli rohkem aega ning sai proovitud auto garaa˛i ajada. Külmalt tuli ikka vähemalt 5-8 korda käiata, siis hakkas paukuma ning siis lõpuks pedaaliga mängides läks käima, aga tühikäigul kukkusid pöörded väga madalale ning suri välja. Sooja mootoriga ei surnud välja, aga pöörded kõikusid. Kui mootor soe oli ja välja sai lülitatud, siis enam käima ei läinud, isegi mitte ei lubanud. Kui aga mootor külm, siis läks jälle käima.
Kuidas temp anduri korrasolekut testida? Andur ise asub vist seal punase ringi sees http://static2.nagi.ee/i/p/559/15/13978961300f58_o.jpg
Lisaks tekkis ka selline küsimus, et sisselaske kollektori peal, kus on Audi kiri, on mul kaks klappi, mida vedru hoiab vastu kollet ning kui kolles peaks rõhk tekkima, saab see sealt väljuda, pole teistel masinatel sarnast lahendust näinud. Kas need sellepärast, et autol oli gaasiseade või on neil mingi muu eesmärk? Küsin sellepärast, et nii silmaga vaadates need küll nüüd ideaalselt õhutihedad ei ole, pole veel proovinud, aga äkki imeb sealt õhku ka peale.
Vanematel autodel sai lugeda veateateid vilgukoodide abil, kas sel masinal pole seda võimalust?
ülks
Registreerunud 04.12.04
postitati 20.01.14 09:15 Tsiteeri
2.3 b4-l peaks vilgukoode saama lugeda küll.
www.teemetünni.ee
[PHP: 20.3% - SQL: 79.7%]
