Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - A6 c6 2006 a õhkvedru probleem
Pealkiri: A6 c6 2006 a õhkvedru probleem (Vastuseid: 7 | Vaatamisi: 1430)
artip
Registreerunud 27.12.13
postitati 27.12.13 21:31 Tsiteeri
tere,
Selline jama, et kui on auto dynamic asendis, siis lähevad mõlemad tagumised padjad tühjaks.
Kui on ülestõstetud asendis, siis on kõik ok. ja võib seista nädalaid.
Üks sümptom on veel see, et ennem lasi automaatselt sõitma hakates auto madalaks, aga enam mitte.
Ükski veatuli ei põle. Kollane tuli armatuuris läheb põlema ainult ülespumpamise ajaks.
Esinduses arvati, et peaks padjad ära vahetama, aga mulle lihtsalt ei mahu see pähe, et miks ta siis ülemisest
asendist tühjaks ei vaju.
On äkki kellelgi mingeid soovitusi ?
andrec
Registreerunud 07.10.06
Auto: A4 B6 R30 VR6 turbo
postitati 27.12.13 21:33 Tsiteeri
Nii ongi kahjuks, et ta ei pruugi igas asendis tühjaks vajuda.
PS! Patju ei pea esindusest ostma.
artip
postitati 27.12.13 21:36 Tsiteeri
Esinduses olid nad u. 380 eurot tk.
Peab siis ikkagi uued padjad vist sebima.
KristoK
Registreerunud 02.08.10
postitati 28.12.13 20:11 Tsiteeri
Kas see solenoidploki viga ei või olla?
Hetkel ühel A6'l sarnane probleem, kummaline on aga see, et mõnikord seisab 3 päeva ja hoiab padjad ilusti üleval. Teinekord läheb ööga peaaegu tühjaks. Igatahes kui probleemi lahendatud saad, anna teada.
artip
postitati 29.12.13 13:20 Tsiteeri
Nats muidugi kripeldab, et miks nad siis mõlemad korraga tühjaks vajuvad ja miks sõitama hakates
auto enam ülemisest olekust järgmisesse astmesse ei vaju sõitma hakates.
Ennem ta seda igaljuhul tegi kui kiirus 50+
Eks annan siis teada, kui lahenduse leian.
artip
postitati 21.01.14 06:20 Tsiteeri
Nüüdseks asi korras. Pidi ikkagi tagumised õhkpadjad ära vahetama. Flameko tegi selle töö ära.
imre208
Registreerunud 21.01.14
postitati 21.01.14 18:22 Tsiteeri
Mis hinna eest flamenko tegi siis?
artip
postitati 22.01.14 21:11 Tsiteeri
Kahe padja vahetus läks kokku 750 eurot ja kaks ja pool tundi tööd.
[PHP: 27.8% - SQL: 72.2%]
