Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 2.0TFSI pöörded kõiguvad sooja mootoriga, lahendus
Pealkiri: 2.0TFSI pöörded kõiguvad sooja mootoriga, lahendus (Vastuseid: 9 | Vaatamisi: 3204)
wa666ou
Registreerunud 30.11.12
Auto: A3 2.0TFSI Q
postitati 13.12.13 15:22 Tsiteeri
Oli omal selline probleem ja sai lahenduse, otsustasin siia ka teistele teema teha.
Autoks Audi A3 2.0TFSI Quattro manuaal 2005.a.
Probleem oli järgnev:
sooja mootoriga hakkasid tühikäigu pöörded kõikuma vahemikus 800-1400 rpm.
Tõusid aeglaselt kuni 1400 rpm ja siis langesid alla tagasi; siis uuesti üles ja alla ja uuesti...
Kahtlustasin erinevaid allikaid nagu tahmane segusiiber, õhu-/vaakumleke, õhulugeja jms.
Aga ka PCV ehk siis karterituulutusega seotud viga. Ja nii oli ka.
Taufis pakuti uut klappi, 40 eur vms.
Aga selle klapivahetusega ei lahenda probleemi päris ära, vaid see tuleb x km pärast tagasi.
Leidsin sellise permanentse lahenduse: BSH - FSI 2.0T PCV Revamp
http://www.bshspeedshop.com/bshstore/products/BSH-%252d-FSI-2.0T-PCV-Revamp.html
Hind on 99 usd + saatmine.
Eikki kaudu (turboklubis) saab ka mõistliku hinnaga ja pääseb vist tollist jms.
Paigaldamine oli väga lihtne ja võttis u 30 minutit.
Probleem lahendatud.
Positive Crankcase Ventilation (PCV) valve failure:
The PCV system lets gases get sucked from the crankcase to the intake manifold when under vacuum. When the PCV system fails it allows positive pressure (boost) to go from the intake manifold back into the crankcase.
Symptoms:
- Idle hunting (i.e. revs climb and dip when idling)
- Minor loss in boost pressure
- Oil pushed through the filler cap
- Slight increase in fuel consumption
- In rare cases there can be an accumulation of oil around the DV and blue smoke present in wide open throttle (WOT) situations.
Treatment:
- Replace valve with newer revision. Please note that the actual revision to use depends on your model. Various aftermarket "permanent fixes" also exist, such as the BSH fix.
- The valve can also be checked by removing the pipe from the PCV that connects to the intake manifold and blowing into it. If air moves freely through it the valve is bust.
postitati 13.12.13 16:43 Tsiteeri
Originaal uus tuleb vanast teistsugune tollega ei tohiks ka probleeme olla. Olen neid ikka vahetanud pole ükski tagasi tulnud.
wa666ou
Auto: A3 2.0TFSI Q
postitati 13.12.13 21:53 Tsiteeri
Algselt postitas: automees6
Sa mõtled siis mingit uuendatud versiooni oem klapist?
Selle kohta ei olegi uurinud.
iguaan
Registreerunud 10.02.13
Auto: B7 A4 Avant 2.0T quattro 147kw '05
postitati 14.12.13 12:02 Tsiteeri
Endal sama mure kummitab, mootoriks BGB. Lugenud ka uute revisioonide kohta originaal klapist ja pole suutnud ära otsustada kumba investeerida. Kui kaua sul see nö pime ees on olnud juba?
E: vaatasin, et seda 06F129101 klappi on tähelõpuga C, E, F, K, L, M, N, P ja Q. Eks kõik ei sobi kõigile aga originaali hinnad jäävad 45€ piiridesse.
wa666ou
Auto: A3 2.0TFSI Q
postitati 14.12.13 19:16 Tsiteeri
Pime klapp on olnud nüüd nädala ja kõik hästi.
Pöörded langevad käiguvahetusel ka paremini. Ennem jäid pisut rippuma.
postitati 15.12.13 18:38 Tsiteeri
Ma algul vaatasin, et se lihtsalt mingi parem lahendus aga sel ju kõik augut täitsa kinni. On se normaalne kui karterituulutus ära kaotada? Mina küll sellist jura ei paigaldaks arvestades, et uus on ainult 40 euri.
wa666ou
Auto: A3 2.0TFSI Q
postitati 16.12.13 06:30 Tsiteeri
Päris ära ei kaota.
http://i781.photobucket.com/albums/yy100/gharamti/IMG_20131127_134410_zpsa81c6536.jpg
http://i168.photobucket.com/albums/u176/BSHStreetandStrip/PCV014.jpg
Pikemat juttu ka siin:
http://www.golfmkv.com/forums/showthread.php?t=58465
postitati 16.12.13 16:55 Tsiteeri
Lugesin ka seda eile polnud meeles, et taga on teine tuulutuse ots ka. Aga ikkagi tühikäigul on tuulutus puudulik ja karterisse koguneb palju niiskust mis talvel pole hea. Kuskil oli pilt ka kus oli koguja sisselaske ja tuulutusklapi vahele pandud, purk oli korralikult vett täis. Välismaa foorumis on ka vastakaid arvamusi selle kaotamise kohta. ;)
iguaan
postitati 03.05.14 18:46 Tsiteeri
Algselt postitas: wa666ou
Kuidas seis on? Endiselt muredeta?
Ise ostsin nüüd viimase versiooni R ja loomulikult probleemid kadunud. Eelmise klapi membraan oli pea täielikult lahti/lõhki.
wa666ou
Auto: A3 2.0TFSI Q
postitati 04.05.14 18:20 Tsiteeri
Algselt postitas: iguaan
Siiani probleemi pole esinenud.
Pöörded võiks küll kiiremini langeda, aga vbl see normaalne. Ei ole võrdlusmomenti.
[PHP: 16.1% - SQL: 83.9%]
