Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - automaatkast
Pealkiri: automaatkast (Vastuseid: 3 | Vaatamisi: 991)
Platea
Registreerunud 16.06.13
Auto: A6 2.0 100kw C6
postitati 12.12.13 20:27 Tsiteeri
automaatkast
Tekkis selline küsimus, et kui ohutu/ohtlik on automaadil sõitmise ajal Minna D-lt S-reziimile ja tagasi. Olen küll kuulnud, et ei tohi teha rikub kasti jne, aga samas olen tähendand, et paljud siiski teevad nii.
mtaudi
Registreerunud 26.02.07
postitati 12.12.13 20:35 Tsiteeri
Mitte midagi ei juhtu - tarkvaraline erinevus ja kasti töös ei muutu ühtlasel sõidul midagi - S reziimil laseb pöörded kõrgemale lihtsalt.
Ka ainukesed kaks reziimi, mille vahel saad liikuda ilma kangi nuppu vajutamatta. Seda selleks, et saaksid kiirenduse jaoks minna sportlikumasse reziimi ja autot seeläbi "erksamaks muuta", kuigi tegelikult on enamus autodel see S asend täiesti mõtetu ja vääne langeb nii meeletult ennem käiguvahetust, et mõistlikum on D reziimis kick-off teha ja siis gaasipedaali asendit muutes juba minekut regullida.
AudiA4Avant
Registreerunud 15.01.13
Auto: Audi RS3, Cabrio B4
postitati 13.12.13 03:28 Tsiteeri
2008 Aasta a4 2.0d 105kw 8k näiteks ei lasegi d asendis pöördeid üle 3000 ainult S'iga saab suuremaid pöördeid. Aga d s ja tagasi lülitamine on täiesti ohutu!
Platea
postitati 13.12.13 05:48 Tsiteeri
No selge, kuigi jah, erinevus on tegelt D ja S asendis et erineval kiirusel on erinev pöörete körgus ja käik, vähemalt tultitroonikul. Ei ole ise sõiduajal katsetand igaks juhuks, et mis pöörded ja muu teeb u 90km/h juures. Aga kui ohutu siis hea.
[PHP: 27.0% - SQL: 73.0%]
