Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Küsimus.Audi 100 v6 halliandur
Pealkiri: Küsimus.Audi 100 v6 halliandur (Vastuseid: 4 | Vaatamisi: 1837)
unimyts
Registreerunud 23.01.12
Auto: audi A4 2.8q,Chevy Van 6.2D bmw 740D
postitati 08.12.13 13:25 Tsiteeri
Tere tarkade klubi,autoks siis 1993 Audi 100 v6 2,6 110kw.
Juhtus selline lugu et läksin poodi ja poest tulles auto enam ei käivitunud,tuvastasime et säde puudu,nüüd sai VAG programmiga asi üle vaadatud ja kirje siis järgmine;
2 Faults Found:
00515 - Camshaft Position (Hall) Sensor (G40)
03-00 - No Signal
00514 - Ignition Point Sensor (G4)
03-00 - No Signal
Saan aru sellest et nukkvõlli andur on vigane ja et ka väntvõlli andur on vigane aga kas on siis võimalik et lähevad need kaks andurit koos või on tegemist veaga millest üks andur on vigane ja samas ka tekitab teisele andurile veakoodi?
Või on tõesti nii et on mõlemad andurid lihtsalt otsa saanud..
Ja veel selline küsimus,kus asub väntvõlli andur,nukkvõlli anduri asukoht on kindlaks tehtud.
Või olen äkki millestki väga valesti hoopis aru saanud :(
Tänan kes vastata viitsivad.
tl470487
aeg maha
Registreerunud 06.07.11
postitati 08.12.13 13:34 Tsiteeri
Väntvõlli anduri osas teed absoluutselt ennatlikke järeldusi. Vaata enne siia:
http://wiki.ross-tech.com/wiki/index.php/00515#00515_-_Camshaft_Position_.28Hall.29_Sensor_.28G40.29:_No_Signal
00514 osas viitab pigem hooratta andurile. Seal samuti ei saa välistada viga juhtmestikus või näiteks mootoril vilets massi ühendus vm.
unimyts
postitati 08.12.13 13:56 Tsiteeri
Algselt postitas: tl470487
Ok..homme üritan massid ja juhtmed üle vaadata,nukvõlli anduri juhtmed tunduvad küll imelikud,pistik tuli koos juhtmetega korpusest välja aga juhtmed tundusid terved olema..kontrollin,tänud.
Raika42
Registreerunud 16.11.08
postitati 08.12.13 16:04 Tsiteeri
Reeglina kasutatakse käivitamiseks halli anduri signaali, ühesõnaga alustaks sellest. Usun. et kui selle ära vahetad ja käima saad, kaob hooratta anduri viga ära...
unimyts
postitati 15.12.13 15:56 Tsiteeri
Algselt postitas: Raika42
Tere,jah sul oli õigus..viga oligi hall anduris..sai see vahetatud uue vastu ja auto käivitub jälle.
Tänud vastajatele ja kaasamõtlejatele.
Head jõuluaega teile ;)
[PHP: 44.5% - SQL: 55.5%]
