Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890 Eesti Audi Klubi foorum - Audi 80 b3 käigukasti õli KORRAS!!!
Tere. Otsisin siit küll teemasid selle kohta,aga täpset vastust ei leidnud.
Kust saab käigukasti õli valada,kui välja arvata käigukasti küljel olev kuuskant polt.Seda ma lahti ei saa,kandid maha keeratud kellegi eelmise poolt
juba.Kuskilt lugesin,et spidomeetri anduri august saab seda ka valada.Vastab see jutt tõele ja kus see asub?Kuskil pilti pole sellest?
Tänan vastuste eest juba ette!
meli666
Registreerunud 30.09.08
Auto: Audi A4-B5 1,9 81 kw
postitati 23.11.13 15:21
Aga mismoodi siis õlitaset saab käigukastis määrata, kui seda korki lahti ei keera?
Endal oli samuti selle sisekuuskantkorgi lahtisaamisega probleem. Aga sai otetud M10 jätkumutter, see otsast natuke ära käiatud ja siis sinna
kuuskandi sisse otsapidi asetatud. Seejärel paari punktiga lasin keevitusega kinni ja tuli lahti ilusti.
Hiljem kruustangide vahel sai igaks juhuks see jätkumutter ringkeevitusega sinna punni külge pandud.
Tegelane5
Registreerunud 26.09.05
postitati 24.11.13 08:22
Spidoka andur on kapotialt näha, vähemalt r4l. On ta juhipoolse koodi juures must pistik, suurem juhtmega on tagurdustuli.
Raido06
Registreerunud 08.04.12
[PHP: 26.9% - SQL: 73.1%]
