Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Soovitage mootoriõli.
Pealkiri: Soovitage mootoriõli. (Vastuseid: 8 | Vaatamisi: 1617)
mustdeemon
Registreerunud 29.06.05
Auto: AUDI 80
postitati 10.11.13 18:18 Tsiteeri
Tere...
Eks neid teemasi on siit läbi käinud aga loodan et, mind mütsiga ei lööda :)
Mure siis selline et, sai soetatud audi 80 1992 2.0 85 kw
Eelmine omanik ei mäletanud millal ta viimati õli vahetas ja õlitase oli ka suht madal aga pidi sees olema mingi long life õli punases pläskus (arvan et VALVOLINE).
Sai siis õlivahetus tehtud ja sisse läks Motul 6100 synergie aga nüüd tekkis koormuse all kerge klõbin ja kõrin mootorisse :(
Olen saanud kaks soovitust.
1. Soovitati panna hoopis 5W - 40 Mootoriõli kuna see pidi mootori vaiksemaks tegeme
2. Soovitati panna Valvoline Max Life (arvatavasti see mis enne sees oli)
Mida teie soovitate või on teil oma soovitus ?
Tänud juba ette ära :D
raemees
Registreerunud 18.09.09
Auto: BMW E90 320dA 2008a
postitati 10.11.13 18:28 Tsiteeri
Algselt postitas: mustdeemon
Tere...
Kuna sul esineb küsimuste reas juba naerunägu?
Mis sellest et klõbiseb kui juba nalja teeb siis vaheta mootor ära ja pane sisse 10w40 poolsünt,
real-illusion
Registreerunud 27.09.11
Auto: A6 3.0 TDI 165 kw Q
postitati 10.11.13 18:49 Tsiteeri
Õli jaoks eraldi teema ka olemas, kus oleks saanud küsida. Ise ei näe mõtet sinna 5w40 panna. Suht sama suur mõte, kui täis sünteetilise peale minna... 10w40 sobib vanematele mootoritele ideaalselt. Kui väga hullult klõbiseb, siis odavam tuleb osta teine mootor. Kui rahast kahju pole ja auto väga meeldib, siis võid ka kap remondi teha...
Life is tough.
Siim89
Registreerunud 07.06.10
Auto: C5 1.8T; C4 2.2TQ;
postitati 10.11.13 18:53 Tsiteeri
Arvatavasti õlipump ei suuda seda uut liiga vedelat õli enam üles välja pumbata. 10W40 on ka minu soovitus.
S4 OMC 238 km/h, ET 13,04
real-illusion
postitati 10.11.13 19:05 Tsiteeri
Algselt postitas: Siim89
Isegi kui suudab, siis vedelam õli võib kõik selle p*** seal kaasa võtta ja midagi ära ummistada. Lõpp tulemusena ta enam ei klõbise vaid hakkab paukuma... Endal kunagu ühel autol sellise vahetuse teinud ja teistele ei soovita...
Life is tough.
mustdeemon
Auto: AUDI 80
postitati 10.11.13 19:27 Tsiteeri
Tänud teile et, mütsiga ei löönud...
Jään siis 10W - 40 peale
V200
Registreerunud 11.09.04
postitati 10.11.13 19:52 Tsiteeri
Kui konkreetsemaks minna, siis Mobil Super 2000 X1 10w-40 on sellisele autole ilmselt nii hea kui üldse olla saab. http://pood.automaailm.ee/est/autokaubad/olid/semisynt/?productID=9082
mustdeemon
Auto: AUDI 80
postitati 10.11.13 20:11 Tsiteeri
Ma soperdan veel kord siia oma lolli küsimuse aga mida rahvas sellisest õlist arvab ?
Kas see jutt peab ka mingil määral paika või on see lihtsalt ilus jutt omaduste kohta ?
http://fixus24.ee/?st=5;info=autotarvikud;toode=115-VA1040MAX-5;/Valvoline_MaxLife_10W40_5L.html
Ma enne unustasin mainida et, mootor natuke ilastab ka...
Tegelane5
Registreerunud 26.09.05
postitati 11.11.13 07:13 Tsiteeri
Väga OK, aga samas ütleks et 10W40 ja 5w40 põhi erinevus on et 10w40 on mõeldud kuni -20 juures kasutamiseks. Kvaliteedi kohta ei ütle see pmtslt midagi.
[PHP: 15.8% - SQL: 84.2%]
