Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi 200 10v diferentsiaal
Pealkiri: Audi 200 10v diferentsiaal (Vastuseid: 12 | Vaatamisi: 1389)
haliseja001
Registreerunud 02.01.10
Auto: Audi 100 86a 2.2T 10V, Audi a6 c4 95.a 2.5AEl quattro
postitati 29.10.13 19:57 Tsiteeri
Tere, kahjuks ma ei leidnud seda teemat( Kindlasti kuskil on kirjas, kuid ei suutnud enam lehti lapata)
Nimelt küsimus selline, et diferentsiaal on all kaks korki, kus õli välja lasta, kuid üks kork küljepeal, kus õli sisse lasta eks ?
Kas need on omavahel ühendatud või käib õli üldse kuskilt mujalt sisse ?
Ja kuna mul autodata ei tööta enam, siis kas keegi oskab öelda, et kui mitu liitrit diferentsiaali läheb ja mis õli keegi soovitab?
Tänades, Sander
postitati 29.10.13 20:00 Tsiteeri
Sa mõtled ikka tagumist diferentsiaali? :) Kui jah, siis muuda pealkiri ka ära. ;) Ehk sellepärast sa teemat ei leidnud. :)
Ülemisest küljepeal olevast täidad. Kui palju sisse läks, ei tea peast. Aga ega rohkem lisada vist saa kui sealt samast välja tulema hakkab. :)
haliseja001
postitati 29.10.13 20:05 Tsiteeri
Algselt postitas: Kivitare
Mõtlen diferentsiaali jah. Olen sigulliga harjunud! :D
Aga miks on all kaks korki? Et vana õli kindlalt välja tuleks ? :D
Ja kas ma võin õli sisse valada, kui diferentsiaal on lauapeal või peab olema autoall, kui rattad on maas ?
postitati 30.10.13 11:03 Tsiteeri
Korkide kohta jällegi ei tea öelda. Aga sellel ei ole küll miskit vahet, kas differ on auto all või laua peal. Kui on samas asendis.
Kui laua peale plaan panna on, siis saad ju kõik välja lasta ja näed selle järgi ka ära kui täis paned. Kui ülemisest avast välja tilkuma hakkab, siis on täis. Katsun küsida, mis see maht seal oli.
haliseja001
postitati 30.10.13 21:19 Tsiteeri
Tänud info eest! :)
kerms
Registreerunud 19.08.12
Auto: Audi 200 2.2 10vt Quattro
postitati 12.11.13 08:24 Tsiteeri
Mis öli siis difrisse läks? Peab omalgi kastis ja difris õli ringi vahetama.
haliseja001
postitati 12.11.13 12:29 Tsiteeri
Unustasingi kohe postidada!
Õli läks siis 2 Liitrit.
Mina panin 80W90 mineraali
timberman
Registreerunud 23.06.07
Auto: MC x 2, AEL
postitati 12.11.13 15:32 Tsiteeri
Igaks juhuks hoiatan, et te pärast ei ehmuks. See difri õlivahetus võib väga vabalt tähendada ka pärastist lekkivad difrit. Endal läbi käidud rada. Kui simmerid vahetatud, siis ilmselt seda muret ei ole!
http://images.spritmonitor.de/556267.png http://images.spritmonitor.de/445659.png http://images.spritmonitor.de/466405.png
haliseja001
postitati 12.11.13 15:34 Tsiteeri
Ma olen ise ka midagi sellest kuulnud!
Uurisin simmerite hindasid ka! Kui ma ei eks, siis ühepoole oma maksis paar euri ja teisepoole oma oli kümme korda kallim! Võin ka eksida!
postitati 12.11.13 23:39 Tsiteeri
Algselt postitas: haliseja001
Jap, sa ei eksi.
rix30
Registreerunud 19.04.09
Auto: Audi S3 1,8T 8L
postitati 13.11.13 04:01 Tsiteeri
All need 2 korki on jahh vana välja saamiseks, esimene on tiffri pikendusel ja teine kogu muu möllu jaoks. Kui juba asi laual siis viska simmerid sama soojaga ringi, pole hiljem muresid- soovitan soojalt!;)
Adolf Hitler!
haliseja001
postitati 13.11.13 07:47 Tsiteeri
Algselt postitas: rix30
Mina sain neist kahest korgist ainult ühe lahti! Ühel oli juba kandid maha keeratud!
Kahjuks ladusin juba tagasilla kokku! Aga eks see lahtivõtmine on juba hulga lihtsam! Kõik on ühekorra juba lahti võetud.
forsin
Registreerunud 01.07.04
postitati 13.11.13 11:04 Tsiteeri
Ma kohe tahaks lisada täpsustust.
See differ töötab erinevalt tavadifritest HAMMASPLOKK-eering olekus.
siis hammas ploki vahele uut õli ei satu ja selline haamerdamine kohapeal lõhub hambad peale mida plokindus varsti ei toimi.
Sellele hammasplokk difrile mina ei soovitaks sisse valada suva mineraal, W90 ollust?
Olen aastaid (lõuna eesti kruusadel) sõitnud taga plokiga, mille tõukas plokki turbos tekkiv boost (mootor oma tööga)
Öliks kasutan CASTROL saf-j 75w140 (150) juba mittukümmend aastat.
Ei tep-id ja mineraal suläd mis ei säilita õlitus kilet.
[PHP: 22.0% - SQL: 78.0%]
